RV.Net Open Roads Forum: Truck Campers: Interesting find: The WaveBox Portable Microwave Oven
 > Interesting find: The WaveBox Portable Microwave Oven
David_in_TX
Grand Prairie, Texas
Posted: 08/06/08 10:23am Link  |  Quote  |  Print  |  Notify Moderator
http://thewavebox.com/
MrTravelDecal
wandering
Posted: 08/06/08 10:44am Link  |  Quote  |  Print  |  Notify Moderator
dang! 200 bucks for a 660watt microwave with a handle on top!!! 12/24volt feature is neat but then the wattage is only 240.
Like old travel decals? me too!
Two cannibals were eating a circus clown,
One cannibal says to the other-
"Does this taste funny?"
cleary
Fairbanks, Alaska
Posted: 08/06/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
That is when it is plugged into your lighter outlet in your car. If you use the included direct to battery cable you get the full 660 watt output. One thing to keep in mind though you will be pulling in excess of 50 amps when you do this. If you wire it into your camper you will need at least #6 wire from the microwave all the way to your battery. This should be fused at the battery!
Chuck
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
Zig
Indiana
Posted: 08/06/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a Wave Cube to take to work, fit inside work locker and to maybe use in the truck camper. It is very small and only zaps at 350 watts. No 12volt power though.
