RV.Net Open Roads Forum: Class A Motorhomes: Weber Q BBQ and propane
 > Weber Q BBQ and propane
Page of 5
mojo41
parsonsburg,md
Posted: 08/06/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 200 in the back yard on a 20lb bottle and a Baby q on the coach that runs off the coaches large propane tank with regular propane hook up hoses.No problems.Will work same way with small screw on bottles.
Elkhartjim
Posted: 08/06/08 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Do as bandmjdavis said...will work just fine.
Jim & sidekick Roxie
38' Bounder DP
scbwr
Wilson NY
Posted: 08/06/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
bandmjdavis wrote:
Yes, I have had the same problem and so have many others according to my research.
The valves on these are very sensitive. Here's what I do and this should fix the problem:
Turn on the valve at the propane tank very slowly.
Wait at least one minute before trying to light the grill.
When you are finished grilling and ready to turn it off. Close the valve on the propane tank first and then turn off the knob on the grill.
Do this each time and it should light reliably and get hot enough to cook all food properly.
Also, be sure to keep the holes in the burner tube clear/free of burned on food. They can affect performance as well.
That's what I would have said!
2001 Dodge 3500 DRW V10 Magnum
2002 Sunline T280SR
Arrow Hensley Hitch
10' Porta Bote
My photo galleries.
Maanpa
Central Point, Oregon
Posted: 08/06/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
We had the same problem when hooking up to our 20# # tank. Called Webers, they said you MUST TURN THE PROPANE ON VERY VERY SLOWLY. THEY WERE CORRECT and that became a pain in the rear. Sometime I was just not slow enough and had to wait and do it again. This was the first BBQ that I was disapointed in of Webers. Got to be a pain doing this, sold our 220 webers bq and have gone back to good old charcoal. Sure start, great taste.
Koran & Darlene
Creole, Cajun & Bayou(Our 4 Legged Kids)
2007 Itasca Suncruise 38T
PressurePro/Progressive SP
Steer Safe/Vantage BB/Stowmaster
Hughes Autoformer
2004 Rubicon
Goodsam/PA/F394282
swebber
Brunswick , MD
Posted: 08/06/08 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Me too ! I use the 20# tank on our Webers.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
DougE.
Fresno, CA USA
Posted: 08/06/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all who have responded, especially the advice from bandmjdavis. I will give this a try. Otherwise I guess I will stick with the blue bottles of propane.
Doug & Judy
2005 Monaco Diplomat
2005 Jeep GC
emmmw
Virginia
Posted: 08/06/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
We initially had a problem with ours getting hot enough when using a 20lb bottle. I called Weber and the rep said to open the knob on the grill all the way and let it run for 1 minute before lighting. Worked like a charm and haven't had a problem with them... yep, bought two... one for MH and one for stick house.
jerb
phillipsburg, KS
Posted: 08/06/08 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
for the record javaseuf, newer propane bottles do have a flow control on them, i have seen them trip many a time hooking on to a regular hose!
Tinstar
McKinney, TX
Posted: 08/06/08 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Not relevant to the problem and I see you will use the blue bottles if it doesn't work for you.
Just wanted to let you know that the green (larger diameter) bottles work just fine too. You will have to remove one side of the hoop rest. I've never used the blue bottles on mine; only the green ones.
I've thought about getting one of the Camping World 11 lb tanks but now I don't know if I will or not.
Never pass up a chance to go somewhere
SteveRankin
Sequim, WA
Posted: 08/07/08 01:25am Link  |  Quote  |  Print  |  Notify Moderator
We have a Q300 at home that runs on a 20# bottle just fine. We have a smaller one for the coach, and it runs off the coach propane just fine.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
Page of 5
