RV.Net Open Roads Forum: Travel Trailers: Extension Cord to TT
 > Extension Cord to TT
cremevette
NE Ohio
Posted: 08/07/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
At the place I store my TT, I plug into a 20 amp gfci outlet. It's about 75 feet away and to this point I have been using a series of extension cords, some regular duty, some heavy duty. I can't eliminate the 75 foot distance, but I think I should switch to a single extension cord.
A friend of mine says to get 10 gauge/30 amp cord to match what is in the TT. I thought that might be overkill. If I only have 20 amps at the outlet, why not run a single 12 gauge/15 amp extension cord to the TT? All I want to do is charge the battery, pre-cool the fridge, and run a couple lights.
There's a tremendous price difference here. I'm not going to spend more if it's over the top.
Thoughts?
Claudia
2007 Keystone Springdale 266 RELLGL - The Brownie Bungalow
2005 Silverado 2500HD, 6.0 - The Mammoth
Nights in 2007 - 30
Nights in 2008 - 48
thomasinnv
where ever i stop
Posted: 08/07/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
as long as you don't plan on running the ac, a regular duty extension chord like a 12/3 would be fine. no need to go heavier, they can get really expensive.
2000 F-350 Extra Cab SD 4X4 7.3 PSD
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
JFG
TN
Posted: 08/07/08 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Thomas is right... for 75ft you can use a number 12/3.
Fred
Learjet
Louisiana
Posted: 08/07/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Ditto ^^^^
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
pete42
Jamestown, Ohio
Posted: 08/07/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Remember electricity through an extension cord is like water through a garden hose.
the power (voltage) like the water pressure is less at the end of a long run.
Low voltage can cause somethings not to work or not to work well.
I have a short 25 foot run here at my house I also have one of those plug-in voltage meters pluged into a 120 outlet.
normal stuff lights, fans, TV, radio even Fridg work ok but if I kick on the AC the voltage reading drops below 120 volts.
so just be aware of what a long run can do.
PETE
* This post was edited 08/07/08 09:20am by pete42 *
tvman44
Southwest Louisiana
Posted: 08/07/08 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Agree but if you are not runnig A/C or MW you will be fine with a 12-3 and save a buch of $$$$
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
pete42
Jamestown, Ohio
Posted: 08/07/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Agree but if you are not runing A/C or MW you will be fine with a 12-3 and save a bunch of $$$$
Absolutely keep the $$$ in your pocket not wal*mart.
cremevette
NE Ohio
Posted: 08/07/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
We're all in agreement. I'll keep the energy use down, and put the money toward "brown pop" or more camping days. Thanks, friends!
A different question ... is there a meter I can plug into the system that gauges my amp consumption at any given time? I have a volt meter, but it would be nice to know what load I'm trying to pull.
Hornet28BHDS
Parker, PA
Posted: 08/07/08 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Get the regular cord. You're not planning on running anything that draws too much. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
dalenoel
Howell, Michigan
Posted: 08/07/08 10:28am Link  |  Quote  |  Print  |  Notify Moderator
When you get into clamp-on amp meters it can get expensive. I have a recording one that cost around $1,000 but you can get others alot less. Here is one for only $75.
Recording what the voltage is will give you a good idea day by day.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and I and maybe a grandkid or two
