Tizi
WA
I have a NL 10 2000 truck camper and I alway dump black water first, then grey. Last time I was out, the black dumped fine (shows under 10% full on guage), but when I tried to dump the grey, nothing came out and it shows over 1/2 full. Any suggestions?
2008 Dodge Ram 2500 QC 4x4 - HEMI
2004 Northern Lite Ten-2000 CD
1998 Glastron GS 180 SF w/ Merc 150 HP
DrScud
On the Road
Could be a bad gauge. Try leaving the grey valve open and running a hose to the sink. Does grey water flow to the sewer? If not it may be your grey valve is broken in the closed position.
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
Tizi
WA
That could be, since when I tried to dump it, knowing there is water in it, nothing comes out...at all.
Could it be that some of the black water contents clogged the drain (they both drain out of the same drain).
If it is the valve, is that easy to repair/replace?
Thanks!
windriderjr
Massachusetts
Tizi wrote: That could be, since when I tried to dump it, knowing there is water in it, nothing comes out...at all.
If nothing is coming out, there are 2 possibilities: a broken valve or a leak. Are you sure there's water in the tank? Testing with a faucet in the rig would prove that one way or the other.
If the black water contents had blocked the drain, you should be able to see it with a flashlight in the pipe from outside. you could always put on some "dish washing" gloves and feel around, too.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
Polishnurse
Schodack, NY
There is also one more possibility. That is the plastic cut out from the tank when it installed was left in the tank and has found it's way to the outlet side of the tank.
A simple test is to leave the dump valve open. Hold the slinky up above the tank height, fill it water from the hose, open the dump valve and let the water flow into the tank. This should move any obstruction away from the discharge. Quickly put the slinky back into the dump opening and see if starts flowing. Just on more thing to try. Bill
g0tr00t
St Petersburg, Fl
i just found some cool stuff in my slow draining gray tank. I shoved my fingers in there and yanked out a chunk of hair along with a grease/soap plug attached to the end of the hair..
Fun part is that we just bought the coach from a dealer..nice eh? Once I yanked that think out, attached the linky and caught my breath from naseau it was a HUGE rush of water. I also try to fill my tanks 2/3 to almost full before I drain it (if you have time at the dump).
I like my black tank to flow like Aquafina.
edited 08/07/08 01:52pm by g0tr00t *
Tizi
WA
Thanks for all of the responses, I will try all of these out!
hershey
Albuquerque,(fulltime) NM, USA
If the valve does indeed to prove functional, you might buy one of the sewer caps that have a harden hose connection on it. Hook up a garden hose to it and turn on the fresh water and open the valve. That should blow backwards into the tank and dislodge anything that might be blocking the drainage.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
Hornet28BHDS
Parker, PA
Let us know what you find out!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Tizi
WA
Got her dumped. I think the wife did not pull it out all the way...:|
Worked perfectly.
