RV.Net Open Roads Forum: Class A Motorhomes: air system on DP losing pressure
 > air system on DP losing pressure
capt mav
Jacksonville fl
Posted: 08/07/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 2000 Winny on a freightliner with a cummins. Going down the road my aft (red Needle) air gauge slowly loses pressure from about 150 down to 120psi at 120 it pumps back up to 150 and then over about a 3 minute period bleeds back down. Front needle(green) holds steady.
When parked both needles bleed down slowly, losing about 30 pounds per day. I recently had my rear air bags replaced,,, cant hear any leaks? thoughts. thanks folks...
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Posted: 08/07/08 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
You got a leak.
w4phj
Vero Beach, FL
Posted: 08/07/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
When mine did this, an independent shop found a blown air bag after Freightliner Orlando couldn't.
Can you build up pressure to 125 and safely get underneath with soapy water and spray all the bags, dryer, air tanks and lines?
2005 Bounder 37U Cat C7 Engine
2007 Dodge 2500 4X4 5.9 Cummins Laramie
2002 Dodge Durango 4X4 4.7 SLT Plus
Amateur Radio Extra Class License W4PHJ
ARRL Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
wolfe10
The varying of air pressure between CUT-IN (120 PSI) AND CUT-OUT (150 PSI) is normal (though both numbers are a little higher than many systems).
3 minute cycles is likely an indication of an air leak or stuck ride height valve. I would think that you would be able to hear the loss of 30 PSI in 3 minutes.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
JFG
TN
Posted: 08/07/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
You do have a leak but the sysytem is taking care of it for now... when it reaches 120, system signal compressor to turn on and fill tanks. I would schedule an appointment with FL and have it checked and repaired.
Fred
wny_pat
Western NYS
Spray bottle with soapy water. Make sure the air pressure is maxed before starting to look. Then spray all the air line connections. Look for bubbles.
DrScud
On the Road
Posted: 08/07/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you block up or somehow insure the coach cannot fall on you while you are underneath. We recently lost a member who was crushed by his coach.
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
ole trucker
Westminster,MD. USA
Posted: 08/07/08 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
IMO, if you are building 150lbs. that is to much! About 130 would be max.Sounds like your govenor needs adjusting. Some times leaks at 150 will disappear at 120-130.
Will and Ina's Endeavor
LIVALIL
Redfox11
Wherever we plug it in! By way of SD
Posted: 08/07/08 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Freightliner was using a quick disconnect system on their air lines, I had one on my 04 Coachman that popped off when I had to hit the brakes real hard, (emergency brake!) one time, talk about a fun few minutes!! We where near Freightliner shop in Ohio, the repair man just plugged it back in, took longer to do the paper work than the job.
Dave & Belinda FMCA 351630 ,HR 111460, DataStormUser 4200
Rallies 9
04 H-R Endeavor 40PAQ,
BlueOX,03 Jeep Liberty Renagade
1 Ragdoll cat 'Sinbad', 2 (Evil) Yorkie's 'Dixie' and 'Rio'
chasfm11
Dallas/Ft Worth Areas
Posted: 08/07/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
We had a split in the sense line that goes to the VDC. If you park in a quiet area, allow the air to build to max and then shut off the engine right away, you should be able to hear that much of a leak and at least localize it. Ours was between the frame rails in the center of the chassis and you could definitely hear it. Both of our gauges were cycling about the same amount and timing as yours.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
1994 Saturn SL1 Toad, Falcon2 Towbar, BrakeMaster Toad Brake
