shenandoahvalley
Shenandoah Valley, Virginia
We level side to side, put tongue jack and rear stabilizeres down. I don't unhook the pigtail.
EllieThomas
Redding, California
Well, I have a chevy silverado. Is that like a GM? So, just for the "just in case" factor, I should unplug it?
Ellie
Redding, California
2006 Jayco Jayflight 20BH
2006 Chevy Silverado Duramax with Allison
plumber1
evensville,tn.
Ellie, yes unplug it just in case.
Safe travels,
Steve
lizziepm
Canada
EllieThomas wrote: Well, I have a chevy silverado. Is that like a GM? So, just for the "just in case" factor, I should unplug it?
Ellie
I'd unplug it!
LPM
muddy princess sara
ohio
this is what we do, everyones diffrent.
pull in as level as possible, leave everything the way it is other then 7way plug. stick the carabeaner thing we hold everything up off the hitch with to the keys as a reminder to plug in the next morning. and place our chocks in the tires. we dont put down any jacks or stablizers. we just crawl into bed and crawl out in the morning.
Hornet28BHDS
Parker, PA
Defiantely put the stabilizers down and tongue jack. Have fun on your trip!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
davidj54
South Alabama
Lots of times if we're just interested in a few hours sleep we just park and go back to the RV, unlock the door and go to bed. If getting a few hours sleep you're not going to run the TV battery down. On my rig that'd be 3 batteries I'd have to run down in a few hours. I can dry camp for 3 days on the two I have in the rv so I can't possibly see how I'd run down three in a few hours running nothing but a fan and the parasitic loads. YMMV.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Gdetrailer
PA
EllieThomas writes "Well, I have a chevy silverado. Is that like a GM? So, just for the "just in case" factor, I should unplug it?"
Chevy/GMC, yes it is a good idea to unplug. Ford and Dodge use a relay on the charge line that only supplys 12V when the TV is running, GM doesn't.
As to why it is important to unplug, imagine your supprise in the morning after your furnace and fridge draw the TV batteries down to the point it won't start!
