RV.Net Open Roads Forum: 2500 3500 350 - what is the difference between chasis?
 > 2500 3500 350 - what is the difference between chasis?
StartingCamping
Chicago
Posted: 08/08/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
After doing my research, I see some "B's" built on 3500 Chevy/Ford chasis, some on 2500. However, I'm unable to find what the difference is online.
bobojay5
Eastern Kansas
Posted: 08/08/08 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
On the Chevy/GMC, the 3500 will have a heavier capacity set of springs and rear end, load range "E" tires, bigger brakes, upgraded cooling and a 4L80, vs 4L60, heavier duty transmission. And I believe??? the 6.0 engine is standard on the 3500.
The Ford would be pretty much the same situation.....
Bob & Sharon: Retired GM & AT&T
2007/06 Chassis, Chevrolet Pleasure-Way Lexor TS
Eastern Kansas FMCA# 386853
Bob N.
Elkin, NC 28621
Posted: 08/08/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
The 3500 series vans are 1 ton chassis, and the 2500 series are 3/4 ton. Most fully equipped B's are heavy enough that the one ton chassis is necessary. Even some of those have limited payload with tanks full or partially full, and most of us underestimate the weight of the stuff we carry with us. Many of the B's have had reported drivability problems that are usually associated with weight and weight distribution. We have a LTV on a one ton Dodge chassis, and it is a handfull in a gusty crosswind. A test drive before purchase is essential on whatever you consider.
Bob N
2002LTV Freedom 2a
djgarcia95928
Northern, Ca. , USA
Posted: 08/08/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
With the Dodge, the 3500 has 1 extra spring on the rear springs.
Dick
djgarcia@earthlink.net
Handbasket
Asheville, NC
Posted: 08/09/08 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
You need to specify whether you mean the 'old' Dodge Ram van, or the new 'Dodge' Sprinter.
Jim, "There will be a time travel seminar last Tuesday at 2:00." Be sure to register in advance."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison ('Loafer's Glory'); '07 Forester 2.5 ( the 'HANDBSKT'); '95 Toyota SR5 V-6 4x4 pickup, ARB locker, Bilsteins, Warn hubs & M8000, etc;
'94 968, M030 swaybars ('DOPPLER')
