ralexis
Flagstaff, AZ
A/C froze up last night. Dometic 13,500 rooftop. We were in the AZ desert and temps were 100 +. I shut down the compressor and left the fan running and the ice melted quickly. No more problems yet. What causes this to happen? Any preventative maintenance suggestions?
Not fun to have no A/C in the desert.
Thanks
LSU Tiger Fan
Retired U.S. Air Force
Pretty good Cajun Cook
Fair Skeet Shooter
Over-the-Hill Skiier
One Lovely Wife
Two Ugly Sons
Six Beautiful Grandkids
One Lucky Dog
thomasinnv
where ever i stop
not much you can do. when they work that hard in those high heats, the compressor does not get a chance to cycle off and on, so the condensation does not have a chance to melt off the coil. just the nature of the beast.
2000 F-350 Extra Cab SD 4X4 7.3 PSD
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
Rollincool
Always Rollin
No humidity in the air and not enough air passing the coils is what causes freeze ups.
When you turn up the thermostat, or should I say turn down, just move it slowly until the unit JUST comes on. That should help. And don't run on slow fan speed.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - Kā¢HiTS 106.7
janstey
Glenwood, IA
Clean your filter often also.
JeffA and KimA
2003 Four Winds Chateau 31S Class C/Ford V10/with slide
2003 Jeep Liberty toad, all 4 down w/brake buddy
Mandalay Parr
Phoenix, AZ
Run the fan on High and make sure the filter is clean.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
javaseuf
Southern Cal
In a properly maintained and operating RV roof air, freeze-up should not be a problem whether on high or low fan.
Other than low refrigerant, if there is sufficient air-flow over the evaporator coil, freezing will not occur.
Things that will reduce proper air-flow are:
Dirty filters
Dirty evaporator coil
Defective blower motor
Bad seal between the supply and return air plenumns
Another cause of freeze-up is the defrost sensor falling off of the evaporator coil. Mine did this when it was new. This sensor is only on ducted systems.
We have had many days in my area with 100+ degree weather and my 15k Dometic runs just fine with no freezing. In fact, when it getts a little too cold, I usually run the fan on low. This forces the compressor to run longer and yesterday, my compressor didn't shut off for 6 hours. No freezing problem.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
tom1984
Olive Branch,Ms
My Dometic 15,000 has always frozen up since new if the outside temps were not above 90. This thing cools great so I have never wanted to mess with it. If the outside temps are not hot enough I just turn the thermostat up a notch and it works fine.
BillyP
Cedar Point, NC
A couple things can cause freezing up of the coils -
1 - poor air flow across the coils. Too many outlets closed (if a ducted unit) or only opening one end, of the discharge on a non-ducted unit. Dirty filter. Something in the duct blocking air flow. The coils are dirty and reducing air flow.
2 - the barrier that separates the return and discharge, behind the register is dislodged (allowing air to recirculate in the plenum chamber).
3 - Improperly installed or defective freeze switch - there is a small thermistor on a pair of wires that pushes into the coils. This switch detects a freeze-up and cycles the compressor.
05 Jayco Seneca 35GS/22k Kodiak/6.6 Duramax
04 Jeep Rubicon Automatic
SMI Silent Partner/BlueOx Aladdin
Billy & Sharon's RV Adventures
javaseuf
Southern Cal
BillyP wrote: A couple things can cause freezing up of the coils -
Hummm....Didn't I say the same things above???
dougrainer
Carrolton
Need a few things to help you. Year/make/model of RV. Make/Model of AC unit and IF ducted and does it have wall tstat controls or are the controls in the roof plenum. Doug
