RV.Net Open Roads Forum: Class A Motorhomes: ANT/AUX/VCR Switch Box???
 > ANT/AUX/VCR Switch Box???
JerryofWV
Charleston, WV
Posted: 08/08/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
When I push the button to send the cable signal to my TV I get a snowy picture until I push it three or four times to make a good connection. Same thing for VCR and ANT.
Is there a way to clean the contacts?
Does someone make a better switch box that I can replace this one with?
Thanks,
Jerry & Dee Dee Pauley
1998 Pace Arrow 36S, 1 Slide, Tag Axle, Triton V10, Front Konis, Rear Track Bar, Banks Ram Air, 2000 Tracker Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
Rich D.
New England
Posted: 08/08/08 10:21am Link  |  Quote  |  Print  |  Notify Moderator
There are any number of good video switchers on the market. I would choose an electronic one over a mechanical switcher for the very reason you are replacing your old one. You need one with enough inputs for all of the video sources (VCR, DVD, Antenna, Cable, Satellite, etc.) six should be adequate. It also needs enough outputs for all TV's plus any recording equipment such as a DVD recorder, VCR (if you still use one). Any good electronics store will have an assortment. Make a list of all your video sources and equipment before going to the store. They will show you what you need. Inputs may be coax, component video, composite video, HDMI, or others. If you have the instruction manuals for the TV's and recording equipment, bring them. They will have diagrams of the input information.
Rich D. Wanderlodge LXi 43'
SS Slacker
Lino Lakes, MN
Posted: 08/08/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
You may have already checked all this but I will throw it out there anyway...
Have you check to make sure the cable lines on the back were tight. Sometimes if they are not tight, but still screwed on, you can get a bad contact until you push the button a few times and that jiggles the unite enough to change the connection of the cable. I had that once and when I snugged them all with a wrench, the problems went away.
Dan & Tracy
2 kids ages 4 and 6
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
JerryofWV
Charleston, WV
Posted: 08/08/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Dan
Yes I checked them for tightness. I have had the same problem in the stick house before and that was the problem.
I would like to find an electronic switch box, but have not been able to find one yet.
DrScud
On the Road
Posted: 08/08/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Take the box out. Take the cover off. Spray the switches with contact cleaner and push them all a bunch of times. Spray again and repeat. Odds are it will work fine for another couple of years.
Jim & Sim - Fulltiming. - - Follow our adventures at: JimandSim.com
98 Foretravel U320 40', Cummins 450 HP/1450 lb-ft, HD4060 Allison, w/rtrder
2000 Jeep Grand Cherokee Laredo / M & G Braking / Demco Excali-Bar
Current location
wny_pat
Western NYS
Posted: 08/08/08 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
DrScud wrote:
contact cleaner
I don't normally recommend Radio Shack, but they have some good contact cleaner. Radio Shack Percision Electronics Cleaner.
dangerbird
Delanson, New York
Posted: 08/09/08 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Caig DeoxIT on my ham radio gear for many years with excellent results. A bit pricey but worth every penny.
Carl
MRUSA
Boca Raton, FL
Posted: 08/10/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
I second the motion for Caig Deoxit. It is amazing stuff. It not only cleans contacts but protects against future corrosion. Extremely effective, even on corroded contacts. Although it is expensive, you only use a tiny bit on each job. One can may last you a lifetime. Well worth its premium price.
Marc, Boca Raton FL
2003 Beaver Monterey 40' triple slide
Blue Ox TruCenter
Acura MDX toad
Unified Tow Brake
Pressure Pro Tire Monitor
Garmin 2610 GPS
Datastorm D3/7000
Sirius Radio
Tivo on board
