TXiceman
(Near) Houston,TX
You do not have to up grade the coach to 50 amp. Simply bring out a separate 20 amp circuit for the added A/C.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Intheloonybin
Twin Cities, Minnesota
TXiceman wrote: You do not have to up grade the coach to 50 amp. Simply bring out a separate 20 amp circuit for the added A/C.
Ken
+1
You could run a heavy (12 gauge) extension cord, or add a 15 or 20 amp outlet that plugs into the pole separately. Most posts have extra 15 or 20 amp outlets on them.
HVAC instructor
2001 Chevy silverado 5.3 V8 1999 Coleman Niagara
2 Great girls 13 and 11
1 Great wife
Looking forward to fall/winter camping!
Wherever I happen to park
That is only about a 10% difference.. And in technology class they tell us 10% more or less = nothing.
I'd do two things
First visit this web page http://www.psrv.net Now I do not recommend you buy (or not buy) their product, but look at it, I built my own (easy to do) which is based on the same concept.
Then put in another 13.5 AC (or even a bit smaller if you can find one) hooked to the PSRV device or something like it
dmatt
Ventura County, CA
Thanks for all the advice and the link. I'm gonna talk to the dealer this week and see what we can do the cheapest. I don't think I'll bother spending the money one upgrading, rather I'll see about adding another.
2007 Four Winds Dutchmen 29R-Ford E-450 V-10 towing a 2008 Toyota Matrix XR
2007 Toyota 4Runner(V-8) towing a 2006 Reinell 220LSE, 5.0L, 280hp GXI
Our camping photos
under the stars
stevelv
FullTimers at Last!
dmatt wrote: Thanks for the advice. I guess I knew the answer but thought I'd ask anyway. It's just not gonna be worth the expenses.
Adding another a/c is a VERY expensive option in my case. It's not wired for it and the dealer says I could not run both on the 30A. I'd either have to upgrade to 50A or run a new 30A cord for the new a/c.
Guess I'll look into alternatives.
I just purchased a 10000 btu portable air conditioner from Home Depot for $399 - they also have an 8000 btu for $299 - IF you have the space to store it the it would be a great alternative - comes with a vent kit that fits into a window - about 4" wide and adjustable to the depth of the window.
The 10k one takes 12 amps - so you can run your roof air and this one on 30amps - if you went for the small one, it runs at 8 amps.
RV Park Finder
Fulltimers
2002 Beaver Santiam 38DST + Banks + 99 Jeep GC
DH,DW,Jake and Indie
dmatt
Ventura County, CA
That looks like a good idea stevelv. Our main concern is that the roof a/c doesn't really cool the back bedroom much. I could put the portable one back there.
How does it cool? Do you think that I could get by with the 8000btu one back there? Thanks
Charlie Q
Brusly, Louisiana
Maximize the efficiency of the one you already have by reducing the work that it has to do. A start would be to have the windows deep tinted, covering the vents with the pillows from C/W, making sure your RV is sealed properly (no air leaks), your A/C coils and vents are clean, clean filter, etc......
Anything over 30' IMHO needs 2 A/C's. Our last 5er had 1 A/C and I swore that our next one would have 2 and it does. 2 - 15K by the way.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
dmatt
Ventura County, CA
Charlie Q wrote: Maximize the efficiency of the one you already have by reducing the work that it has to do. A start would be to have the windows deep tinted, covering the vents with the pillows from C/W, making sure your RV is sealed properly (no air leaks), your A/C coils and vents are clean, clean filter, etc......
Good idea except I don't want to tint the windows too much. I bought those vent covers from C/W but with two of my vents,the opening was not deep enough for them to stay in. A/c has been cleaned.
stevelv
FullTimers at Last!
Check out my thread in the Class A section on using solar film on the OUTSIDE of the glass - makes a huge difference and is cheap.
The 8k and 10k units are the same size - I was thinking about amps when I suggested the 8. The unit sucks air through a filter at the back, cools it and blows it out the top - it has a remote control too which is neat. There is a pipe similar to a washer/dryer vent pipe that goes to a plate that you fit into a window opening (very neat looking) that ejects the hot air out. It's quieter than my roof ac.
We have two slides in the front and it cools that area down so you'll be fine with one in the bedroom.
