just5erit
Zebulon, NC
I have a 30 footer and set the front landing gear down and then turned the back landing gear down until it was snugg. The front landing gear is the power jacks with the standard one leg on each side and the back are the manual turn down jack. While camping, I was still feeling the foot traffic movement inside the 5er when I was napping. Any suggestions on stabilizing the 5er better to tighten her up???
2001 Chevy 1500HD 6.0L (stock)3/4 frame
DrawTite brake controller
DrawTite 15K Hitch
Firestone Airbags
2006 Flagstaff 30' 8528DS Bunk Slide/Super Slide
Mayoman
Tennessee
Look at JT strongarms triangulation stabalizers.
2008 Ford F450 Superduty Diesel dually
2008 Keystone Cougar 293SAB
fordsooperdootydieselsmoker
OrangeCountyCalifornia
We use the UltraFab tri-pod hitch support. Takes out a great deal of movement without costing a bunch of cash. And it acts as a theft deterant if used with a substantial pad lock!
At Camping World
Veebyes
Devonshire
The 5er is sort of like a boat.....it moves. Want something that does not move? Get a house on a concrete slab. Everything else will move to some degree. You just get used to it. For one nighters, if there is room, we don't unhitch or put rear stabilizers down. We just take a little weight off the truck with the front legs down.
RV: slightly pre enjoyed 2006 Alpenlite 34RLR LTD
2006 Chevy 3500 crew cab LT 6.6L Diesel
john b
anywhere USA!
Take a look at one of the advertizers on this site the Steadyfast stabilizers we love ours! I had something similar to the Jts and like these much better,a lot of research went in to these and 4 years R&D! IMHO!!!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
wayne_tw
South Dakota/Georgia
JT's Strong Arm Stabilizers will solve your problem.
tvman44
Southwest Louisiana
JT Strongarm Stabilizers will do the job, love ours.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
JIMNLIN
Big Cabin, OK
Who needs a slab for a house. I've had Meneries disease and has left me motion intolerant so I use adjustable chocks between the wheels for forward and backward motion/pin stabilizer in the front for side to side and Bal stabilizer in the rear for rear side to side movement. Snug them all up just so they take the movement out. May have to readjust in a day or so.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
mydazeoff
Annapolis MD
Partly depends on what you want to spend and additional weight you're willing to carry around. Since its on wheels I just want to get it firmed up for the stay. I drop the landing gear down at least half way before lowering the extensions, unhitch and get things leveled up. Then drop the rear support jacks, I use a wood support block and try to keep a diamond shape. The last thing I install is wheel chock between the wheels. I made up two pieces of 4X4" drilled the middle and added a threaded rod with a nut on the end to allow tightening. I welded a steel plate to one end of the rod and a handle on a nut so no tools are needed. Need a picture send me a private message. No complaints in our 5ver even with a couple of grand kids running in and out.
2006 GMC Sierra 2500HD Duramax LLY, CC, LB
2005 Jayco Eagle 323RKS
Reese 15000 lb. 4 way hitch
Annapolis, Maryland
JohnG3
Morro Bay, California, USA
Roto Chocks and Winfield stabalizers.
John, Elaine and Mia the 60 pound lap dog.
F-250 SD,Excab, V-10
2004 Titanium 26E31DS with Bug Room.
"I'd rather be in the boat with a drink on the rocks than
in the drink with a boat on the rocks"
