RV.Net Open Roads Forum: Hybrid Travel Trailers: Tires Balanced ?....WTH
Open Roads Forum  >  Hybrid Travel Trailers
 > Tires Balanced ?....WTH
SLSAntigua
Pennsylvania
Posted: 08/11/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was told that here is no need to balance the tires. I was also told It might not be a bad idea since the tires are different from the originals. My old tires were bias, the new ones are radials. Basically got a new set of five at no charge, (that's another story), had them mounted, balanced and filled with nitrogen (part of the package). They recommended balancing in order to avoid the possibility of vibrations. As for the nitrogen, will it increase my mileage? Probably not but it will keep them cooler. I'll let you know how they do when I return from 2000+ mile trek to Fort Wilderness and back in 3 weeks.
Steve, DW, 2 DDs
2006 Starcraft Antigua 215SSO
2008 GMC Envoy SLT
Voyager Brake, Reese WDH and sway control
Redeye2280
Riverside, Calif.
Posted: 08/14/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
I sure would like to know of a good axle/alignment shop out here in Riverside,Ca.!
2008 Toyota Tundra
2006 Antiga 21SSO
2005 Rescue Shelter Pound Puppy Shep. Mix
1950's Something Sweetheart of a Fisherwoman Wife
