RV.Net Open Roads Forum: Tech Issues: Semi Permantent Magnetic XM Antennae Install
 > Semi Permantent Magnetic XM Antennae Install
martinandanne
Dallas, Texas
Posted: 08/08/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hi
I'm wanting to attach my magnetic XM antennae to the top of my RV, but have discovered that there are no pieces of metal to attach it to.
I was thinking of finding a small piece of stainless steel and gluing it on to the roof and affixing the antennae to that. (I am then going to run the wire down through one of the roof vents.)
What type of adhesive would you recommend for doing this? My MH has a TPO roof.
Thanks
Martin
2008 Four Winds 5000 23A
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 08/08/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
3M 5200. Just make sure you will never,ever want to remove the antenna. There is no need to do anything other than put the 5200 on the antenna and position it on the roof.
You can also use some other 3M 52xx stuff that will let go if and when you want it to.
marobrown
Crystal City, Mo
Posted: 08/08/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a ladder on your MH you could also look at a mirror mount antenna at a truck stop for road tractors. You could mount the antenna on the back on your ladder.
2004 Ford F-150
2006 Starcraft 2409
Camper Modifications and Pics
Fleet Man
Western WA
Posted: 08/08/08 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
No need to put it on the exterior/roof if you have a rubber or fiberglass roof. In our TT, I placed the antenna in the top of one of the cabinets. In our current MH, I have the antenna placed inside under the front roof cap. Good reception in both situations and no holes or outside wires to contend with.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
Gdetrailer
PA
Posted: 08/08/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Umm.. you might want to test the stainless to see if a magnet will stick to it. There are many grades of stainless and not all are magnetic.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 08/08/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
As I recall, stainless steel won't work with a magnet. Test it first
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
Mousefart
New Jersey
Posted: 08/08/08 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I used to work with various grades of stainless. Even though some grades are magnetic, they are no where neer the holding power you would get out of regular steel. You might as well just glue the antenna itself with the 3M 5200 and skip the plate, or buy a different antenna.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab 4x4, 4.7L HO, factory tow, 3.92 gears.
Equil-i-zer Hitch, Prodigy.
Yamaha EF2400 Generator (quiet, cause I care!)
Learjet
Louisiana
Posted: 08/08/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
yep, I get 3 out of 4 with my XM ant. inside like above ^^^^^^
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
quark
Hillsborough NJ
Posted: 08/08/08 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
I use the antenna from my home kit on the trailer. You can drill holes in the base to mount it to any surface using any existing screws you might have on the exterior. The antenna has an adjustable hinge so you can mount it on the side.
http://shopdelphi.com/consumers/satradio/skyfi/skyfi2/SA10103-11P1/
MH: 96 Ford E350 7.5 Fleetwood Jamboree Searcher
TV: 1995 Nissan Quest
VTT: 16' 1963 Yellowstone "Canned Ham"
Controller: Tekonsha P3
Hitch: Equil-i-zer .
http://www.vintage-yellowstone.com/
OzarkPreacher
S.W.Mo. God's Country
Posted: 08/08/08 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
same here. I put mine on the dash when traveling and it works great. Once set up I can position wherever I need to.
