RECVEH2005
Camano Island, WA, USA
I just finished sanding and painting my tailgate for the umpteenth time. The manufacturer (Custom Flow) makes a big deal about the quality of their "powder coat" finish. As far as I'm concerned, it's not worth a hoot! Why can't they or won't they paint these tailgates with the same kind of enamel as my truck is painted with? My truck surely doesn't get rusty with paint peeling off every year!
Mike Scheer
Mike & Donna Scheer
Camano Island, WA
2006 GMC 2500HD D/A(LBZ), 4wd, Ext Cab, SB
2004 Okanagan 29-5Y, 1 slide
Slow Six
Shaunavon, SK.
I had the same problem plus the gate was starting to crack and weaken at the pivots. I repalced it with an aluminum one which is better built, looks better, latches better and is lighter.
sirdrakejr
Las Vegas, Nevada
A coat of Rustoleum works wonders and is cheap. When mine shows wear that is the cure!
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
alpenliter
Olympia WA
sirdrakejr wrote: A coat of Rustoleum works wonders and is cheap. When mine shows wear that is the cure!
Frank
Same here, painted it when I first got it, looks as good today as it did then. Sand 'er down, prime it, paint it, forget it.
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
RECVEH2005
Slow Six:
Do you recall where you purchased your aluminum tailgate? Do you remember the brand name?
Thanks.
Mike
RECVEH2005
sirdrake jr & alpenliter:
After you have used the Rustoleum, what kind of paint do you use for the top (final) coat?
Thanks.
Mike
sdfleetwing
SD
rustoleum clear coat for the final coat. They have many different colors for the base.
Greentreena
British Columbia
Paint will last much longer with a clear coat on it. Plus it gives a beter colour match to the truck. Just remember to raise the pin high enough the clear the tailgate.... opps good thing for touch up paint!
ryanallie1
Magalia, Calif
Hi All.
Why go through all of the work of sanding and re-painting every year. Sounds like a very easy fix to me. If your not a Full-Timmer, why don't you take your 5er tail-gate off durning the winter months, and put your stock tail-gate back on. Works wonders on our TV and our 5er's Hitch. We don't even have rust on our hitch, or even the Hitch Bed-Rails. I keep both the Hitch and the Bed-Rails waxed and keep them clean. I remove the hitch after each use. After 12 years, we still have all of the original stickers on our RBW "LiL" Rocker Hitch. Good Luck. Happy Camping. Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
biljo99
Bonaire, Ga, USA
Take your tailgate to a bedliner spray in place and have them spray it. Guarantee you won't have to worry about painting it ever again. I had the one on my 2002 Dodge RAM 2500 sprayed years ago. I asked them to do it when they sprayed in the bedliner.
2008 Ford F450 CC PSD LB DRW 4.30 Moonroof King Ranch 6.4 auto Tow Boss Navigation Sirius/XM radio Audiophile
Reese 16K hitch
2004 Everest 364Q MotoSat MD500
