RV.Net Open Roads Forum: Class B - Camping Van Conversions: Quiet Furnace?
otbiker
Kerrville TX
Posted: 08/09/08 05:19am Link  |  Quote  |  Print  |  Notify Moderator
We have the typical Suburban WakeMaster 5000 in our LTV. Guaranteed you won't sleep when its on... We use a cube heater when we're on shore power, but would like to have a more permanent solution.
Any recommendations about a replacement propane furnace that is quiet, and that would fit in the space of the Suburban?
I'm willing to throw $$$ at this problem if there is a solution...
Marty in Kerrville
04 Leisure Travel / Mercedes Benz / Freightliner Van...
Polishnurse
Schodack, NY
Posted: 08/09/08 05:39am Link  |  Quote  |  Print  |  Notify Moderator
They sure tend to make a racket. But so does a new refrigerator when you first plug it. Then after a couple of days the mind tends to block it out. Just like people live near air ports or along a railroad line. I know I get used to mine running or perhaps after a few days I'm so tired I black out. Don't think this is much help. But I know others will come with gas LPG heaters and such. Bill
Atlee
Mechanicsville, VA
Posted: 08/09/08 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I must be weird or something. That heater has never bothered me. To me it's not much different than sleeping with the AC on.
Erroll, Mary, Duffy the Wonder Doxie & "Ollie"
1996 RoadTrek 210 Popular, on 1995 Chevy Chassis
mockturtle
Northwest
Posted: 08/09/08 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Because the noise is intermittent, it is more intrusive. Yep, they are noisy. Some people use an Olympian Wave catalytic heater but I'm not sure there would be room in a B.
What I'm wondering is: Are you really having to use a furnace in TX in August??
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
mumkin
Minot ND USA
Posted: 08/09/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
You might want to look into an Espar heater like the truckers use. It runs off your battery and gas tank (regular or diesel) and once it is up and running makes almost no noise for the rest of the night.
Not cheap though... actually relatively cheap to run, but they cost about a thousand dollars.
Mumkin
kenuck
Burnaby, B.C.
Posted: 08/09/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I haven't tried this but it may be worth a look: http://www.ehow.com/how_2170281_noisy-rv-furnace-quiet.html
What's really needed of course is a multi-speed system with a furnace capable of low/high or variable output. Haven't turned up anything yet. (My home gas boiler automatically throttles from 10K to 150K BTU according to the load, so I know it can be done)
Also, check out:
http://www.rvpartscenter.com/prodselect.asp?SID=11&DID=84&CID=288
Claims to be quiet but no sound specs.
Hope this helps
tom_kat
way upstate new york/lake george area
Posted: 08/09/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
i think atwood has a furnace with a 2 speed fan,
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
VE3ESN
Ontario, Canada
Posted: 08/09/08 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Our Suburban furnace is right under the bed, and it's a noisy sucker for sure. In the winter, we use the furnace before we tuck into our thick warm sleeping bags, and then don't turn it on until the morning. The Roadtrek Versatile also allows us to close off the "bedroom" or the "bedroom/kitchen/bathroom" from the rest of the van to conserve heat. Finally, we have thermal insulators on all window curtains, and an aluminum bubble insulator on the back window, and under the bed. After all, we're in Canada, the great white north!
Jerry & Susie
1996 Roadtrek 190 Versatile (Dodge 5.2 L)
FMCA F390585
loving retirement
SF Bay Area
Posted: 08/11/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Also, check out:
Hope this helps
I do not know about your "B," but in mine I do not have a distance cold air return duct back to the furnace to add soundproofing material. My noisy self contained furnace is about 14" x 14" x 24" with no exterior cold air return ductwork to insulate as the link called for. I believe the answer is with a better designed fan and a variable speed motor.
otbiker
Kerrville TX
Posted: 08/12/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
I've looked into the Olympian Wave furnaces, but am concerned about combustion air. There's gotta be an answer. You're right, there's simply not enough room to insulate anything. By design, if you slow the fan motor, the burner won't fire...
