topwop39
Akron,Ohio
I have taken my new 5er out on several trips so far this year, just returning from Disney last night. What I have noticed is that I get different degrees of movement (shaking) when parked at campgrounds. when someone walks I can feel the whole trailer shaking. Some trips alot, some trips not as much. I use the BAL delux tire locking chocks every time. The only thing I do differently is how far I extend the front jacks(stabalizers). Could this be the problem? Do the tripod king pin stabalizers really work? Thanks for any input.
2004 Chevy Silverado 2500 4x4 crew cab
2007 Coachman Chaparral 269 BHS 5'er
prodigy brake controller, pullrite 14K superglide
Akron Fire Local 330
lv2rom
Kansas City, Missouri
First let me say that some shaking is inevitable (you are sitting on the trailer suspension). I have just added things over time, and think I am relatively stable now....Riser blocks under the front jacks and rear stabilizers to limit travel, wedge blocks (home made) between the tires, blocks in front and behind each wheel, a king pin stabilizer (I think they do make a different in not allowing the overhang to wiggle around). I'm sure many others will have their own ideas and opinions, but this is what works for me......Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
Drifter_59
Concord, NC
This is what I use and they work great.
http://plugitright.com/Page3.html
Enjoying Life with the 4 legged pal, Dexter (boxer/lab mix).
The Mule - '06 Chev 2500 HD, CC, SB, LT2, 6.0L, 4.10, Bilsteins
The Wagon - '07 JayFlight 30.5 RLS
hendersonb
Fairfield, PA
"The only thing I do differently is how far I extend the front jacks(stabilizers)"
Yes IMO this will make a big difference! I use a full stack of those plastic leveling pads on each rear stabilizer. Also I have found that on uneven ground I extend both front landing legs the to the same length and level with boards. My 5er is very stable using this method.
Robert
2008 Ford F350 Super Duty 6.4 PSD
2008 Montana 3400RL
barryp
On the road
topwop39 wrote: I get different degrees of movement (shaking) when parked at campgrounds.
IMNSHO, it won't go away, I've bought several gadgets that were advertised to be the cure-all with no real success. I've also talked to many folks who swear by (and at) some of the doo-dads I've thought about buying.
Can you sing On the road again?
2002 F350 Lariat 7.3L PSD CC DRW
2005 Challenger 29RKP
husker 2
Sequim WA
Quit the horseplay!!! Nothing you do will stop it 100%. This is not a house setting on a foundation. Go with the flow and pretend you have a house boat RV.
2004 GMC 2500 6.0L CC SB Reese 16K Slider Prodigy BC Jayco 24 ft 237a Quest 5er
A decrepid old driver a foxy navigator and one cranky Griff puppy named Bandit. Look for a "Big Red" license NEBR 1
Chickie
Slatington,Pa USA
We had the same problem in our toy hauler I put the Ultra-fab stabilizers on and now the trailer is rock solid. next week we go for a trip and I will really check it out. The JT strongarm stabilizers are just about the same as the ultra-fab units and vise versa. I used to go crazy when you felt someone walking into the trailer. From what I found out at home I won't even need my kin pin stabilizers anymore so I have a little more I can load in the storage bin.
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
2008 Goldwing GL 1800/2008 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
Retired and loving it.
Horseplay
NC
I didn't do nuthin' I swear!
husker 2 wrote: Quit the horseplay!!! Nothing you do will stop it 100%. This is not a house setting on a foundation. Go with the flow and pretend you have a house boat RV.
jerryspoolman
Corning CA
spend more time camping.. after a while you will hardly notice the movement. Stayed in a desert/dust wind storm last year 65MPH winds.
Going 40MPH down the highway into the wing folded my TV antenna Blade into a V.
Just Jerry and Vangie
Pickle2
Riva, Maryland,
Best just to get used to it. By the time you get rock-solid, you will have spent too much and spent too much time setting-up and breaking camp.
Pickle at Pickldom.
Wife, Deb; Daughters: Brenna(13), Alysson(12)
Dog: Chocolate Chip (English Springer Spaniel) "Okay, in or out, but don't keep pawing at the door!"
03' Dodge, 2500, Long Bed, 4x4, HO Cummins Diesel.
2004 29BHBP Wildcat by Forest River.
