heaterswa
Plainfield, IL. USA
We just finished loading all our gear into the Durango, drove down to the Pilot fuel stop and filled up the diesel, then jumped on their Cat scales. Here are the results:
STEER AXLE : 8720 lb.
DRIVE AXLE : 1420 lb.
TRAILER AXLE : 7500 lb.
GROSS WEIGHT : 17640 lb.
Doesn't seem right to me that the steer would have so much weight, I was expecting less up front and more on the drive axle due to all our gear was loaded up front and nothing in back.
Any comments?
-Bryan
Me, Wife and 3 daughters
TV: 06 GMC 2500HD D/A SLT 4WD / Prodigy / Reese Signature 18K
TT: 04 KZ Frontier 2505QSS-F / Hensley
FW: 07 KZ Durango 315BH / Fifth Airborne / Sidewinder
Ft. Wilderness, WDW.
April 2007
kennethwooster
Perryton Tx USA
I bet something is backward. Your drive axle should have a lot more weight then the front axle.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
shorthair
vancouver, wa. usa.
Weigh it again there is NOOOOO way your steer weighs 8720# I'm pretty sure if you ever did get that much on it it would be U shaped. I would think 4400# steer 5900 on the drive will be a lot closer your hitch would have to be on the front bumper to pull that much off the drive axle. Plus with only 1400# on the drive tires I'd expect major wheel spin & little forward motion.
wittmeba
Roanoke, Va
It doesnt appear that either axle weights of the TV are correct. Even with a 5th wheel, your front and rear should be much closer to being the same. You probably added more than 1420# just from the pin weight of the 5er.
Bruce & Carolyn Wittmeier
Viet Nam Vet 1968-69
I was born in Great Falls, Mt. My parents moved when I was 5.
I found them when I was 10 - they were in California.
balvert
Windsor, Ontario
I have to agree. You need to reweigh the rig. Even my Dodge diesel front axle with my fiver hooked up only comes to 4500 pounds and this axle is rated at 4700. Your rear weight is definitely wrong as well. Your numbers just don't make sense.. Reweigh it. Casey
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
railbird
Lacey, WA
If the gross is right and the trailer axle is right, then you are about 1000 over on the truck. I think your truck has a GVWR of 9200.
2007.5 Chevrolet LMM Dually
2003 Sprinter 276RLS
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
If your weights are correct you have a severly overloaded front axle and your front tires are also severly overloaded.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress
Picture of '93 Mountain Aire Story of it's death by fire and explosion
Fulltimer50
Eloy, AZ
Perhaps you pulled onto the scale backwards??
George
99F250XLT/SC/LB/4x2/3.73LS/gauges/JNB BypassReg/ Airlifts/Rancho 9000s/DS Predator Tuner/203*TS/Coolant filter/Jimmyjammers/Oilguard/4"turbo back/Suncoast tranny/BD EBrake.
06 Newmar Cypress 29KSRE 5th wheel, Mor/Ryde IS, Kodiac disk brakes
shorthair
vancouver, wa. usa.
Fulltimer50 wrote: Perhaps you pulled onto the scale backwards??
Normally they won't weigh you till you are turned around.
SAS!
So. Cal.
My guess would be that your trucks rear wheels were on the split in the scale sections with most of the weight on the front section?
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
