RV.Net Open Roads Forum: Dinghy Towing: Harbor Freight Magnetic Tow Lights (Changing Bulb)
Search only in Dinghy Towing
 > Harbor Freight Magnetic Tow Lights (Changing Bulb)
franky14
Maryland
Posted: 08/09/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone ever changed a bulb in the Harbor Frieght Magnetic Tow lights before. I love the lights they have lasted a long time but one has burned out (not the wiring)and I can not figuare out how to get to the bulb. I removed the four screws that held the magnetic base on and that was not it. It appears to be a totally sealed unit. This is starting to drive me nuts, anyone ever change one before?
Thanks,
Glenn
Art D
Baton Rouge, La.
Posted: 08/09/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen sealed lights before on other equipment. Probably have to replace the whole fixture.
Geaux...LSU...
franky14
Maryland
Posted: 08/09/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
THanks that is what I was thinking just making sure I was not missing something obvious.
robatthelake
Vancouver Island
Posted: 08/09/08 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure on Yours but on Mine you pry the Lens Off! There is a small "Coin Slot" that gives a starting point.
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
mtrumpet
Hamburg, NY
Posted: 08/09/08 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
If they're inexpensive lights, they're probably sealed. Many trailer lights are like that. The lights on my Haulmark enclosed cargo trailer are like that. You just remove the entire assembly from the rubber grommet holding it in, and replace with a new unit. It wasn't until I spent some time destroying one of the light assembies trying to replace the bulb, that someone clued me in that they were sealed and to just replace the entire unit. This may be a similar case with regard to your lights.
mtrumpet
2000 Southwind Storm 30H
Ford Triton V10 6.8L
F53 Chassis
Davis Tru-Trac
Henderson Rear Trac Bar
Carquest/Moog Steering Damper
Monroe RV Gas Magnums
Goodyear G670 RV's
jdkd123
Northeast
Posted: 08/09/08 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have sealed lamps on my Rv. Replacement of the unit(s) runs between $4-$7 ea. depending on which unit. I must say it is one stupid design.
JDKD123
2005 Coachmen CONCORD
GO SOX!
topflite51
In The Desert of Nevada
Posted: 08/10/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Had a set of tow lights from HF, and that's the way they were.
David
Just rolling along enjoying life
