RV.Net Open Roads Forum: Class C Motorhomes: Inverter Brand in Jayco Greyhawk 27DS
 > Inverter Brand in Jayco Greyhawk 27DS
simbatoner
Portsmouth, RI
Posted: 08/10/08 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Can someone tell me the brand, model, and location of the factory installed inverter in the 2006 jaycos?
Also what outlets/appliances does it power?
Thank you.
2006 Jayco Greyhawk 27DS
Towing 2006 Honda Odyssey Touring Edition
on a MasterTow 80HDS
Using the Lowrence Iway 500C to find our way
paulin
No. CA
Posted: 08/10/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about your MH, but our 2007 Jayco Seneca has a Xanterra 400 watt inverter installed on the floor under the bedroom closet. It powers only the entertainment center outlets and is, IMO, too small to do the job. We are on our fourth attempt, via our dealer, to get one that works. Thank goodness for Jayco's 2 year warranty.
Paul & Linda
2007 Jayco Seneca HD 34SS Duramax
2005 Saturn VUE
"Monty", "Maggie" & "Murphy" the mighty Shih Tzus
FMCA #F375077
dry_fly
Northern Arkansas
Posted: 08/10/08 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Our '08 Jayco Melbourne has a Xanterra 400 watt also, and it controls the same things as mentioned in the previous post.
kopy kat
reno, nv
Posted: 08/11/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 27DS, and the Xantrex 400 watt inverter is located next to the water heater. You have to remove the large pull out drawer that is located under the closet. It is wired only to the plugs that are up front at your TV and DVD station. I've thought about having additional wiring installed at the TV location in the bedroom--should be an easy install.
The key to having a successfull TV situation up front is to replace the 14" flat tube with a newer LCD--otherwise, you will have to fire up the generator before turning on the inverter for the TV, then shutting the generator down once the TV comes on-?!-
Also--check on the IOTA converter next to the inverter--make sure it has the (2) 30 amp fuses showing at the one end of the case--if not, the RV dealers have a bulliten out from JAYCO to upgrade the fuses from the 25 amp to 30 amp (I did mine myself). If the fuses blow, you'll not get converted power from the generator to recharge your battery set.
I sure like my 27DS--hope you'll enjoy yours as much!
Larry
2006 Jayco 27DS---"Camp MiMiPaPa"
paulin
No. CA
Posted: 08/11/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
The key to having a successful TV situation up front is to replace the 14" flat tube with a newer LCD--otherwise, you will have to fire up the generator before turning on the inverter for the TV, then shutting the generator down once the TV comes on-?!-
I wonder if this has been the problem with mine? Is this because of a high inrush current when the TV is turned on? I've been suspecting this and wondering if a larger capacity inverter would be the answer.
Paul
