RV.Net Open Roads Forum: Have you had Front Bunk End Water Leaks!!!!
Open Roads Forum  >  Hybrid Travel Trailers
 > Have you had Front Bunk End Water Leaks!!!!
Page of 5
Shari and Jamie
Vermont
Posted: 08/10/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Nope not a leak here. It has rained almost all summer.
Shari and Jamie
Reno and Max
2007 Kodiak 235
2006 Ford Expedition
VolFamily
Tennessee
Posted: 08/10/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Two year old Jayco 23B; towed and camped in torrential downpours with NO leaks. Knock wood.
MMike
Langhorne, PA
Posted: 08/10/08 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, we have a bunk leak! We own a 2006 17' Roo. Only leaks when towing in heavy rain. There was a SIGNIFICANT amount of water in the storage pocket below the bunk. Two small pieces of clear duct tape on the lower corners (where the hinge is) seem to solve the problem.
Rescue16
Virginia Beach, Virginia
Posted: 08/10/08 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses so Far!!! MMike it is nice to know that Duct tape still can fix almost everything!!!!
Rescue 16 - United States Navy Retired and Proud
Lovely Wife Carla
The Crew Chrissy, Alicia and Johnathan
The Camping Dog HyperZoe
2006 Flagstaff Shamrock 21SS
2004 Jayco 10X PU
2005 Ford E250 Eclipse Signature Series Conversion Van
kodiakcanuck
Ottawa, Canada
Posted: 08/11/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Yes, 07 Kodiak 214 leaks small amount into the storage pass through towing in heavy rain. I towel placed in the right spot works for now. Dealer replaced front bunk end, but still leaks. Must be the seal or the hinge, just haven't figured it out yet.
2007 Kodiak 214
2004 Dodge RAM 4x4,4.7L - darn, should have had a HEMI
Maxumbob
Michigan
Posted: 08/11/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
We had the problem when we owned the Trail-lite Bantam (if I knew we would be driving in the rain, I would duct tape around the front opening; that seemed to take care of the problem.) I have not had a problem with the Roos, but have not been in real heavy rain. I guess it is not surprising for that to happen; as put by somebody previously, it's like the front end of the trailer is going through an earthquake and hurricane at the same time.
2006 Rockwood Roo 21 SS
2005 Silverado Crew Cab 1500
Scott_C
NJ
Posted: 08/11/08 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, front. Dealer replaced all damage and installed replacement single seal EXACTLY like FR instructed them to. It was shorter than my original from the factory - didn't fly in my book. I dealt personally with FR and received replacement primary and a new secondary seal (one of the various revisions of that secondary) and installed myself. Will be changing to the new push-on trim with weatherstrip bulb.
2008 Shamrock 21SS
risingsun
Prescott, AZ
Posted: 08/11/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
No leaks here on this 2006 23SS.
2006 Rockwood Roo 23SS
2001 GMC Yukon SLT
MBOLTONCO
Upstate NY
Posted: 08/11/08 11:01am Link  |  Quote  |  Print  |  Notify Moderator
None here. Jayco 19h
Campfire Time
Wisconsin
Posted: 08/11/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Yes, a few years ago we towed several times in downpours. Found a little bit of water in the right side storage area behind the bench cushions. The bed itself wasn't leaking. It was a small opening on one side of a seam molding, which is about 4 inches below the bed hinge on our trailer. The original caulk dried and shrunk. I sealed it, and no problems since.
Chuck D.
'03 Jayco Kiwi 17a, '03 Chevy Trailblazer EXT, Garmin Nuvi 200 GPS
Photography is my obsession: http://coldwater.smugmug.com/
“Adventure is just bad planning.” - Roald Amundsen
Page of 5
