RV.Net Open Roads Forum: Class C Motorhomes: weight distribution
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > weight distribution
ronfisherman
SE Michigan
Posted: 08/11/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Had a portable RV scale company stop by my place to weigh ours.
Front left 3,000 lbs. Front right 2,850 lbs total 5,850 lbs
Rear left 7,025, Rear right 6,900 lbs. Total 13,925. Thats 425 lbs over weight on rear axle. MH was loaded with full fuel, water, camping supplies and etc. Water is 100 gallons. Don not need that much when traveling. Have cut water down to 20 gallon. Which drops rear weight by 600 lbs. MH is in signature below.
Saf-TTE tire monitor
BitWriter
Chula Vista, CA
Posted: 08/11/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
JDLEE1979 wrote:
Are you just saying if you run out of water and run the pump dry it will be damaged?
I can't say with experience but that is what the owner's manual on the water pump says. According to my manual, the water cools the pump as it flows through the pumping chamber. In my opinion, the pump will spin too fast because it was designed for resistance caused by the water.
I know that it doesn't happen instantly because the few times that I have run low on water, the pump didn't burn out. However, I shut off the pump as soon as I heard the higher pitched growling.
MS Bowhunter
Collierville TN
Posted: 08/15/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Steer Axle= 14,200
Drive Axle= 23,700
Tow Vehicle w/ Golf Cart & 105 Aux Fuel Tank= 10,700
Gross Combined Weight= 49,600
Fully loaded for 2 week trip.
GVWR= 56,660 GCWR=80,000
Still have room for about 30000 more lbs of junk, one huge advantage of a truck conversion!
