CampingUSA
California
Every year I drain the water heater I get soaked. What is the secret to draining it without getting wet ? I follow the directions in the owners manual by opening the facuets before removing the plug but I still end up getting wet. We have a 10 gallon water heater and I think I get all 10 gallons on me. Last time I thought I would just stand to the side and let the plug shoot out and it did. I stayed some what dry but the plug shot out about 20 feet. There has got to be an easier way to drain it. What is the correct way ?
Horseplay
NC
Got that on video?
DKean
Mays Landing NJ.
Try releasing the pressure with the pressure relief valve.
Traveling Texans
College Station, Texas
When I drain mine I first remove the plug, then open the pop-off valve then i open the kitchen hot water valve. I open the kitchen valve because it is the furtherest from the water heater, I really don't know if that means anything or not, just the way I do it. This way the water starts out slowly because it is having to draw air through the drain as the water runs out.
2007 Chevy 2500HDCC D/A SWB
2006 Outback Sydney 28FRLS
Polishnurse
Schodack, NY
As DKean said, use the relief valve first, then don't stand near it as it drains.
The Texan
Summer: A Cool Climate Winter: A Warm Climate
DKean wrote: Try releasing the pressure with the pressure relief valve. This is what I do and never get wet, other than a hand.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03
FMCA #F203528
'05 HR Endeavor, 40PRQ w/400 Cummins - With -'05 GMC Sierra SLT, CC Z-71, the pusher
'07 Arctic Cat 500A & Wilderness Kayak, riding in the pusher -
Our Current Location
Terryallan
NC
Could also try opening the low point drains, letting them run till they stop. But the easiest way is to pop the valve, and then remove the plug.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Oakman
MO
I release pressure with the valve and then open both of the low point drains. When the water stops draining I remove the anode rod.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
seatboard
South Carolina
Next time, have a bar of soap with you.
Pickle2
Riva, Maryland,
seatboard wrote: Next time, have a bar of soap with you.
Naked, of course.
Pickle at Pickldom.
Wife, Deb; Daughters: Brenna(13), Alysson(12)
Dog: Chocolate Chip (English Springer Spaniel) "Okay, in or out, but don't keep pawing at the door!"
03' Dodge, 2500, Long Bed, 4x4, HO Cummins Diesel.
2004 29BHBP Wildcat by Forest River.
