RV.Net Open Roads Forum: Do you add water & chemical to tanks during the drive?
 > Do you add water & chemical to tanks during the drive?
Davea07
Auburn, WA
Posted: 08/10/08 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Everyone,
I just want to know if any of you add 5 to 10 gallons of water to all your Tanks so it sloshes around during the drive for cleaning purposes and if you add any chemical or detergent to the mix.
I have been doing it for a while and I normally put in some chemical with it.
This upcoming trip I think I want to get the tanks much cleaner.
I am thinking of putting in some Laundry detergent to get the tanks allot cleaner, especially the black water tank. My DW says the laundry detergent will suds up to much.
Maybe dish washing detergent instead of laundry detergent will be better , what do you think?
If you do this, what do you add to the water?
Thanks in advance for any suggestions or commits.
Thanks
Dave A
2008 Denali 295BS-DSL, Equalizer WD hitch, Prodigy brake controller.
2007 Dodge Ram SLT 2500 6.7L, 6sp automatic.
Bigcoyote
Mesa, Arizona, USA
Posted: 08/10/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I always a little water & chemical to the tanks before & after a trip. It helps keep the odors down.
EDIT - if you are going to use detergent - use the ones designed for dishwashers or a washing machine ( low or no suds ) -- trust me.......
John , Juli & the kids
2005 T@B T-16 - T@Basazi
2006 GMC Yukon XL Denali
2008 Pontiac Solstice GXP
1957 Shasta 15 footer ( project )
All Photos
Camp Photos
Polishnurse
Schodack, NY
Posted: 08/10/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I never put any thing in the holding tanks. I used to put in Pinesol, but heard that will eat the O ring in the dump valve. If anything a cup of Bleach in the gray tank. A few gallons of water in the black tank.
If you want your tanks clean get a tornado spray washer. The black tank is just what is says it is, a black tank. I'm not even thinking about serving or storing anything in there but what its intend use is, which is a holding tank till I can dump into an approve place. In this case I don't believe in better living thru chemistry. JMHO Bill
Horseplay
NC
Posted: 08/10/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just plain ole water. Use a Flush King and is all you could need.
john b
anywhere USA!
Posted: 08/10/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Always a normal 2ozs and a couple of gallons of water. With a active enzyme product it can slosh every where to eat up the waste, worked fine for years now.
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
Pat & Rich
Lancing, TN
Posted: 08/10/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard that adding a bag of ice and some water when you head out will clean up the back water tank.
Pat & Rich
3 Poochies (Chris,Candy & Precious)
2003 38' Cruise Air Pusher
dhamblet
Olympia, WA
If you are determined to put something in the tank use powdered Borax and/or Rid-ex. But I generally don't put anything in my tank and use my Tornado tank washer every so often.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
tvman44
Southwest Louisiana
Posted: 08/10/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I always keep a few gallons of water in the black tank. When we use the head we flush with extra water so as to have plenty of water in the black tank for a good dump
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
campnis4us
Greenville,SC
Posted: 08/10/08 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have found that we keep our tanks cleaner since we have been putting about 3-5 gallons of water in the BW tank with some chemicals after we have fully cleaned out the tank.
This allows the tank to slosh during the trip home and again on the trip back out.
2004 Forest River Wildwood 27RLSS
2005 Ford 250 Power Stroke Turbo Diesel
Bumpyroad
Virginia
Posted: 08/10/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
but don't put a lot of water in. you want the ice to slide around and bang a bit, not just slosh around in the water.
bumpy
