RV.Net Open Roads Forum: Fifth-Wheels: How do you flip axels?
 > How do you flip axels?
Monty-Rob
Charlotte,NC
Posted: 08/10/08 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
I did a search but cannot find the answer to flipping axels. I have a new F450, I don't have the hitch yet but I am guessing I will have to raise my Wildcat. Within 11 months I am getting a Carri-Lite but want to safely pull the old fiver till I get the new one.
StoneyPgh
New Kensington, PA Steeler Country
Posted: 08/10/08 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Flipping the axles is simply mounting the springs on top of the axles.
This assumes that the springs are mounted under the axles at the factory.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Jordan 2020 Ultima
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
tvman44
Southwest Louisiana
Posted: 08/10/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
It also involves welding new saddles on the axles.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
trop-a-cal
Palm Coast Fl
Posted: 08/10/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
It also makes the steps to short, as they get higher.
Monty-Rob
Charlotte,NC
Posted: 08/10/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
I looked under my Wildcat and the springs are already on top of the axels.....now what?
ol Bombero-JC
Posted: 08/10/08 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Since you "don't have the hitch yet" - why not wait until you do?
Maybe you won't need to change the spring mounts with spacers (or?).
Drifter_59
Concord, NC
Posted: 08/10/08 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Longer shakles or mounts.
Enjoying Life with the 4 legged pal, Dexter (boxer/lab mix).
The Mule - '06 Chev 2500 HD, CC, SB, LT2, 6.0L, 4.10, Bilsteins
The Wagon - '07 JayFlight 30.5 RLS
Peg Leg
Anderson, IN
Posted: 08/10/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Remove axles, old shackles, weld steel tubing to the frame, new shackles and reinstall axles. Tubing should be the same width as the frame and a depth to match the amount of lift you want, wall thickness of 1/4" should do the job.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
Monty-Rob
Charlotte,NC
Posted: 08/10/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I will wait till I get the hitch installed in my new truck to see exactly how I match up.
I could not remember what needed to be done to raise the fiver.
SKnight
Georgia
Posted: 08/10/08 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Since the spring is already on top of the axel then lift blocks from the local 4X4 shop should do nicely.
I don't get lost, I investigate alternative destinations.
See a guy in the campground with a telescope, that may be me.
2001 Dodge 2500 Cummins HO six speed.
2002 Springdale 286 RLDS TT
