Monty-Rob
Charlotte,NC
I did a search but cannot find the answer to flipping axels. I have a new F450, I don't have the hitch yet but I am guessing I will have to raise my Wildcat. Within 11 months I am getting a Carri-Lite but want to safely pull the old fiver till I get the new one.
StoneyPgh
New Kensington, PA Steeler Country
Flipping the axles is simply mounting the springs on top of the axles.
This assumes that the springs are mounted under the axles at the factory.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Jordan 2020 Ultima
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
tvman44
Southwest Louisiana
It also involves welding new saddles on the axles.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
trop-a-cal
Palm Coast Fl
It also makes the steps to short, as they get higher.
Monty-Rob
Charlotte,NC
I looked under my Wildcat and the springs are already on top of the axels.....now what?
ol Bombero-JC
Since you "don't have the hitch yet" - why not wait until you do?
Maybe you won't need to change the spring mounts with spacers (or?).
Drifter_59
Concord, NC
Longer shakles or mounts.
Enjoying Life with the 4 legged pal, Dexter (boxer/lab mix).
The Mule - '06 Chev 2500 HD, CC, SB, LT2, 6.0L, 4.10, Bilsteins
The Wagon - '07 JayFlight 30.5 RLS
Peg Leg
Anderson, IN
Remove axles, old shackles, weld steel tubing to the frame, new shackles and reinstall axles. Tubing should be the same width as the frame and a depth to match the amount of lift you want, wall thickness of 1/4" should do the job.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
Monty-Rob
Charlotte,NC
I will wait till I get the hitch installed in my new truck to see exactly how I match up.
I could not remember what needed to be done to raise the fiver.
SKnight
Georgia
Since the spring is already on top of the axel then lift blocks from the local 4X4 shop should do nicely.
I don't get lost, I investigate alternative destinations.
See a guy in the campground with a telescope, that may be me.
2001 Dodge 2500 Cummins HO six speed.
2002 Springdale 286 RLDS TT
