teddysmith1952
Layton, UT
Hi all,
I just arrived at my RV spot in Wendover NV (middle of nowhere) and discovered my air conditioner is blowin hot air. The temp outside is 95 degrees. The unit is blowing OK however, the fan and A/C both just blow outside temp air. Normally, when I switch to A/C, I can clearly hear the compressor kick on but now when I go from fan to A/C, there is no change. Desperate! Any ideas?
Golden_HVAC
Fulltime, CA, USA
My guess is you already have the thermostat set to a low enough temperature?
The problem might require the attention of a RV mechanic.
There are only a few problems that are easy to check.
If you have a bad thermostat, you need a parts store at the least, mechanic to determine and fix it at the most.
Same thing if you have a bad capacitor, bad relay on the circuit board, bad wiring someplace.
From what you described so far, the parts I think might be bad are the circuit board relay, thermostat, capacitor, or a burnt wire someplace.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
teddysmith1952
Layton, UT
Thanks Fred. I might be in trouble. No RV mechanic within 100 miles. I'm hopefull someone might chime in with a simple fix. Not likely but .............Thanks again Fred
trop-a-cal
Palm Coast Fl
Make sure you have enough amperage going to unit. Turn everything else off. After it gets going (compressor) then it draws less amperage and other things can be turned back on. Good luck!
Admiral
Lodi, Ohio
Just a thought...if your thermostat is bad it may not operate the furnace either. Check the heat and see if that works. If it's the thermostat, maybe Golden can advise you which 2 low voltage wires you can jump for a temporary fix.
2004 Damon Daybreak 2960F
05 Honda Element LX
In a democracy two wolves and a sheep can vote on what to have for dinner.
teddysmith1952
Layton, UT
Hi all. Really appreciate. I tried turning off all otehr power. no go. I will try the furnace to see ifthat works.
teddysmith1952
Layton, UT
Hi again all,
My son is up on the trailer roof and removed the A/C housing. The compressor is definately coming on when the A/C is turned on. Still hot. Thermostat? If so, is there a bypass that was suggested?
Thanks again!
teddysmith1952
Layton, UT
One note. I'm trying the furnace which is seperate from the A/C however I'm not sure if it will kick on sense it only goes to 90 degrees and the temp is 95
TXiceman
(Near) Houston,TX
If the compressor is running, the suction line (larger line to compressor) should get cool and eventually start to sweat and the discharge line (smaller line to compressor) should get warm...actually hot. If this is not happening, you got problems. Look for some oily spots on the lines which could indicate a refrigerant (oil) leak.
You should hear and feel the compressor start.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Brodie3Az
Arizona
Hello Teddysmith,
You did not say what size the AC unit is. Being that the temp in the trailer is 95 degrees, it may be a while before you notice cooler air. Run the blower on low. Open all windows to ventilate the RV of superheated air.
Last resort, buy ice and a table fan to get you thru.
Good Luck!
