RV.Net Open Roads Forum: HELP!! Trying To Find Water Temp Sensor, 94 Cummins B-Series
 > HELP!! Trying To Find Water Temp Sensor, 94 Cummins B-Series
tcr1016
Leander, TX
Posted: 08/10/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I am changing my temp sensor since I am getting false reads.
In the pic below, I thought the temp sensor is what I circled in red. But I disconnected the wire when the engine was running, to see if the gauge would not register. But when I disconnected the wire the temp gauge stayed the same. So I am guessing this is not the temp sensor.
I called Monoco and Cummis and neither knew where the sensor would be. Can anyone tell me where the temp sensor is on a 94 Cummins B-Series, so I can get the new gauge put in?
1995 Safari Sahara 33' (5.9 230HP Cummins Diesel) Diesel Pusher
Daily Driver even to the store, Home Depot, restaurants, etc.
1 Dog (Great Dane/Greyhound Mix) goes everywhere with us.
My License Plate Frame Reads:
MY BIG
TEXAS SIZE SUV
Jaseds
NE TN.
Posted: 08/10/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I had one exactly where you show in picture ,I installed it for a separate temp gauge. there also is one I think on the rear of the head .That works the stock gauge and light. Mine was on a pickup so it could be somewhere else. But check the head on rear.
Have A Nice Day
tcr1016
Leander, TX
Posted: 08/10/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I checked the rear of the head and did not find one. Where else could it be??? You would think they are trying to be like Japanese motors where they play hide and go seek with components.
HK40USP
Santee,CA
Posted: 08/10/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
I saw a connection on the side of my radiator, I assumed this was the temp sensor but could be wrong....Jim
1996 Gulfstream Sunvoyager, 34 ft, no/slides
Spartan Chassis, B5.9 230 hp Cummins
Jaseds
NE TN.
Posted: 08/11/08 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
jim, that could be a low coolant sensor. My Spartan has it on the Radiator tank for low coolant. temp sensors should be on the head or coolant manifold somewhere attached to head on most all cummins .tcr ,did you look on the sides also of head,if no others are on eng. it would have to be the one in picture.
HK40USP
Santee,CA
Posted: 08/11/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
ahhhh....thank you sir....I would like to change my temp sensor since it is 12 yrs old.....thanks, Jim
