RV.Net Open Roads Forum: Tow Vehicles: Ford + GM = A good thing?
Search only in Tow Vehicles
 > Ford + GM = A good thing?
Engineer9860
Eagle Scout dad
Posted: 08/11/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
More trivia ~ Heavy duty Dodge and GM trucks use the same (AAM) rear ends.
Well sort of. The AAM 11.5" is the same in both the GM, and Dodge trucks. However the Dodge version uses a speed sensor/tone ring built into it's axle units. The GMs use the transmission output shaft for the speed signal.
The AAM 10.5" axle in the GMs is the old GM 14-bolt, the 10.5" AAM axle in the Dodges are of a design similar to the AAM 11.5" axle. No parts will interchange between these axles.
The AAM 9.25" SFA in the Dodges will interchange differential parts with the 9.25" IFS axle in the GMs.
While we are looking into trivia.....
GM, and ford have both used the same ZF S6-650 6 speed manual transmission in their 3/4~1 ton pick-ups since 2001.....
Well that is until GM dropped manual transmissions altogether in 2007.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
lesmore49
canada
Posted: 08/11/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
There would be lots of things to figure out. Like which pickup diesel. The Duramax or the PSD ?
lesmore49
surveyorjp
Missouri
Posted: 08/11/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I love your sense of humor!
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
dodge guy
Chicago, western subs.
Posted: 08/12/08 10:26am Link  |  Quote  |  Print  |  Notify Moderator
82corvette wrote:
Wow, if we could have an F250 with a Duramax!
More like a Silverado/Sierra with a CUMMINS!
* This post was edited 08/12/08 10:33am by dodge guy *
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
pronstar
The LBC
Posted: 08/12/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing new.
Even BMW & Bentley used GM trannies for years.
Beyond this, most of the cars on the road today use parts from the same pool of suppliers.
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
Tim from Alabama
PERPLEXED
Posted: 08/13/08 04:37am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm. That would be interesting.
A GMC Sierra Z71 with a Mercedes I-4 diesel engine, Allison tranny, 4.11 Dodge rear end, Cadillac front grill, Toyota towing capacity, Nissan Maxima headlights, BMW suspension, and Volvo interior.
Brings to mind the song by Johnny Cash about the
49, 50, 51, 52, ...... Cadillac.
But, honestly, the 4 cylinder Mercedes diesel engine in a full size 1/2 ton truck would be a good idea for fuel economy and durabilty, still having the horsepower and torque as the 5.3l V8.
If I don't meet your expectations
Maybe you should lower your standards.
roosky01
Lodi, WI
Posted: 08/14/08 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I wish the truck segment would work like the class 8(semi truck)does. That way you could pick any powertrain configuration you desired. Only thing that would change between brands would be the cab /body configuration. I have a feeling that would make the Dodge Ram extinct though.
My configuration would be Ford F350(not dually)CC/SB 4x4 King Ranch, Cummins,& Allison. And maybe a company could build a practical air ride system to be factory installed as an offering also.
I know it will never happen but, it would be nice to see Deere and Cat throw their weight around in the diesel p/u market too.
2008 Challenger 30TRL 5th wheel
2005 Chevy 2500HD CC/SB 4x4 Duramax (with some goodies )
2008 John Deere 850D XUV Gator 4x4 Diesel
larry barnhart
wenatchee. wa usa
Posted: 08/14/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
This would be bad if it drove like a ford but good if it drove like a chev.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
Patster
Ontario Canada
Posted: 08/15/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
The days of the over the road highway tractors with numerous possible engine/driveline combinations is coming to an end. Cat has said it will not be part of the on road diesel market. Greater integration of the whole vehicle is required to meet the new standards and Cat has seen the cost involved for an ever shrinking market share. No word on Cummins yet. If GM and Ford go ahead with joint venture development of engines lets just hope GM does the design phase. Ford's OHC modular engines are big(wide), complicated, costly and not all that good on gas or powerful. GM's GEN III/IV pushrod engines are much more powerful, compact, and seem to get better mileage with a less complicated and more durable design. Ford's chosen path has also eliminated the option of using a modular displacement or "active fuel management" system.
roosky01
Lodi, WI
Posted: 08/15/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
All thanks to the government.....Higher prices and less choices. I sure am happy that everyday we try our hardest to emulate a communistic society...
Sorry to get off-topic.....About the only thing I feel that Ford would bring to a partnership would be the seats in a King Ranch model p/u. Those things are soooooo comfy!
