mholman
Utah
Just bought a 2004 montana that had been sitting since new. It has a thetford foot flush toilet. At first the disk valve in the toilet wouldn't hold water, I worked it back in forth and kept flushing it, now it will hold water.
My problem is, you are supposed to be able to hold the foot flush valve down part way to fill the bowl without the slid valve opening. Most of time I cant find the spot where the water will run and the valve doesen't open. is there an adjustment for this???
P.S. the foot valve doesent lift up and the instructions on the lid say to depress halfway
Thanks for any help
edited 08/10/08 09:37pm by mholman *
7th Cav
Someplace
Lift the valve to fill.
7th Cav
2004 Damon Intruder 350
Workhorse W22
1997 Ford Explorer Toad
pcm1959
St Augustine, FL
DITTO. Lift the foot lever to fill the bowl. pcm
ReneeG
Meridian, Idaho
That's what I was going to say - lift the valve to fill.
2006 282TS 32' Komfort
1999 Ford F250 4x4 XLT SD Triton V10 with Tow Package
Prodigy Brake Control
Magnaflow Cat Back Exhaust, FIPK, and TransGo Shift Kit
Hensley Arrow
Dave and Renee plus Champ, Molly (in spirit), Missy and now Maggie Along for the Ride!
javaseuf
Southern Cal
Wow. Many here that don't know *&%#!!!!
The Thetford operation manual, available on their web-site, for ALL of their models with a foot pedal says to PRESS the pedal down 1/2-way to fill the bowl.
The Dometic Sealand toilets are the ones that you lift up on the pedal.
If when pressing the pedal half way down on a Thetford toilet, it empties the bowl, then the mechanism needs to either be lubed or adjusted. It is too tight so when the pedal gets depressed, it starts to drag the knife-valve linkage with it before it is supposed to.
edited 08/10/08 10:20pm by javaseuf *
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Hench
So. California
mholman wrote: P.S. the foot valve doesent lift up and the instructions on the lid say to depress halfway
Thanks for any help
For the ones recommending he lift the valve, he said the foot valve doesn't lift up so that won't work. Try the post above, you should be good to go (no pun intended).
2004 Fourwinds 27D Two-Slide Class C
and a bunch of toys
javaseuf
Southern Cal
Hench wrote: mholman wrote: P.S. the foot valve doesent lift up and the instructions on the lid say to depress halfway
Thanks for any help
No pun intended but this here is funny!!!!!!!
Modracer
central cal
On the back of my Thetford there is a small metal linkage that goes from the water valve to the flush valve. It rides in a slot on the flush valve. Put a dab of grease on the end of the end of the linkage. I had to use one of the DW's makeup mirrors to help me see how it operates.
06 HR
Ambassador 38PDQ
04 Liberty
