RV.Net Open Roads Forum: Tow Vehicles: Ford's latest reflash does indeed improve mileage
Search only in Tow Vehicles
 > Ford's latest reflash does indeed improve mileage
Page of 5
Capt Skup
Southern Maryland/Nantucket
Posted: 08/15/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
My mileage report was in reference to towing a almost 13,000lb high profile fifth wheel. How is that similiar to a 6,000lb travel trailer? Towing my 5500lb boat/trailer yields over 12mpg, a load more similiar to your trailer. My '98 Dodge QC gasser was lucky to hit 8mpg towing the same boat/trailer at 60mph.
BTW, Ford is not the only manufacturer that has issued TSB's, new flashes/reprograms.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
GMC Dmax
Snohomish, WA
Posted: 08/15/08 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
That's good mileage Capt, especially given the gears and mass of the truck. I pull my 13k 5ver with a 2008 Dmax 1 ton SRW and don't see a whole lot better than that. Worse if there are any passes involved.
Regarding re-flashes: The LMM equipped GM's have a recall/reflash going on right now. I don't know the details exactly, but I've gained about .5 mpg since I got the reflash done. The engineers will continue to make improvements as more testing and user feed back illuminates problems.
windellmc
Indianapolis
Posted: 08/15/08 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
surveyorjp wrote:
Capt Skup wrote:
I consider it pretty damn good. My 1998 gas Dodge 1500 Laramie QC 2wd truck never saw over 9mpg towing a 5500lb boat and trailer and it sure was not near the comfort or quality of any of my Ford diesel trucks. 10.9mpg horrendous? Have you ever pulled a high profile heavy fifth wheel?
Yep, with a truck heavier than yours. The truck alone weighs 10,000 lbs (its a 2001 Dodge Ram 3500 4x4 DRW cab chassis with the Cummins HO with the six speed manual outfitted with a dump bed).
That truck has pulled loads heavier than your trailer numerous times, and can easily get better than 10 mpg doing it, usually getting around 12 mpg with the heaviest loads. I am sure your truck is more powerful and faster and has more fancy do dads, but we use this truck for work, not loafing around with an RV, although it has towed a fifth wheel RV trailer outfitted with a gooseneck adapter on a few occasions.
My point is, 10 mpg is horrible for diesel engines that just a few years ago could get mid teens pulling similar loads, albeit slower. Ford will be glad to get that new scorpion diesel under the hood.
It's not the weight that really pulls down the highway fuel economy it is the air drag. My diesel truck can get close to 18 mpg empty but drops to 10-11 towing our trailer. For reference my F150 with 5.4L engine only made 7-7.5 towing. I would be shocked if your 360 did any better than that towing my trailer.
My trailer is really tall and is basically a big box on wheels. Comparing that to a flat bed with a backhoe on it is not a good comparison. My parents tow a 15k horse trailer and get 12 mpg vs my 8k travel trailer at 10 mpg.
MM49
Brighton, MI, USA
Posted: 08/15/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Dieselgem wrote:
This is the latest flash TSB
6.4L—VEHICLES BUILT BETWEEN 8/3/2007 AND TSB 08-13-3
1/3/2008—MODULE REPROGRAMMING
FORD:
2008 F-Super Duty
ISSUE
ACTION Some 2008 F-Super Duty 250-550 vehicles
equipped with a 6.4L diesel engine and built Follow the Service Procedure steps to correct the
between 8/3/2007 and 1/3/2008 may require a condition.
calibration update which will include: SERVICE PROCEDURE
• Diesel Particulate Filter (DPF) regeneration will no
longer initiate at idle and in power-take-off (PTO) Reprogram the powertrain control module (PCM),
mode. When “Drive to Clean Exhaust Filter” is transmission control module (TCM) and IC.
displayed on the instrument cluster PTO and/or 1. Reprogram the PCM/TCM by selecting Module
stationary elevated idle (SEIC) must be Reprogramming PCM to the latest calibration
disengaged/inactive in order to properly clean the using IDS release 55.10 or later, patch 24 or
DPF. The “Drive to Clean Exhaust Filter” later and 56.1 or later. This new calibration is
message will continue to be displayed until an not included in the VCM 2008.7 DVD. When
adequate drive cycle is completed. If the vehicle reprogramming the PCM on automatic
is operated in a manner to allow effective transmission equipped vehicles the TCM will
automatic cleaning the message center will also automatically be reprogrammed to the
display “Cleaning Exhaust Filter” indicating normal latest level. Calibration files may also be
regeneration process. obtained at www.motorcraft.com.
• Diagnostic and malfunction indicator operation
improvements for P0128, P0196 and P2002. 2. Reprogram the IC by selecting Module
• Enhancements to reduce vehicle surge and Reprogramming IC to the latest calibration
improve resume function during cruise control using the same IDS release.
operation. NOTE
• PTO content; vehicle speed output signal used by THE PCM/TCM AND IC ARE REPROGRAMMED
vehicle upfitters will now read zero when vehicle SEPARATELY.
is stopped and PTO idle engagement RPM
ramp-rate revised. Please print out the Customer Information Sheet
and insert into the glove box Owners Guide for
• Improvements to reduce P0544, P2031 and
future customer reference. (Figure 1)
P242A set on long deceleration after cold start.
• Exhaust gas recirculation (EGR) disable function
at idle is now determined by exhaust temperature
and not idle time. This calibration also includes
the following instrument cluster (IC) message
center display updates: Drive to clean exhaust
filter, cleaning exhaust filter and exhaust filter
drive complete.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date June 17, 2008 PAGE 1
TSB 08-13-3 (Continued)
NOTE OPERATION DESCRIPTION TIME
REPROGRAMMING CONCERNS/ERRORS MAY 081303A 2008 F-Super Duty 0.5 Hr.
BE CAUSED BY THE DATA LINK CONNECTOR Automatic Transmission:
(DLC) OR VEHICLE COMMUNICATION MODULE Reprogram The
(VCM) BECOMING DISCONNECTED, LOW PCM/TCM/IC Includes
BATTERIES ON THE IDS OR THE IDS GOING Time to Check For DTCs
INTO ANY TYPE OF SLEEP MODE, OR LOW Authorization Decal Not
VEHICLE BATTERY VOLTAGE. IF THERE WAS Required (Do Not Use
AN INTERRUPTION DURING REPROGRAMMING, With 12650D)
MAKE SURE THE ORIGINAL IDS SESSION THAT 081303B 2008 F-Super Duty Manual 0.4 Hr.
WAS CREATED FOR THE VEHICLE IS NOT Transmission: Reprogram
DELETED. IF THE ORIGINAL VEHICLE SESSION The PCM/IC, Includes
IS NOT USED OR DELETED BEFORE THE Time to Check For DTCs
MODULES ARE COMPLETELY REPROGRAMMED, Authorization Decal Not
FURTHER REPROGRAMMING ERRORS CAN Required (Do Not Use
OCCUR. THE MODULE RECOVERY PROCEDURE With 12650D)
IS NO LONGER AVAILABLE AND IT IS CRITICAL DEALER CODING
THAT MODULE SWAPPING IS NOT PERFORMED CONDITION
FROM VEHICLE TO VEHICLE. TO REGAIN BASIC PART NO. CODE
COMMUNICATION WITH A MODULE THAT HAS RECAL 04
BEEN ERASED DURING REPROGRAMMING,
RESUME THE ORIGINAL SESSION ONCE THE
IDS IS REBOOTED.
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty
coverage limits/policies are
not altered by a TSB.
Warranty coverage limits
are determined by the
identified causal part.
PAGE 2
Figure 1 - Article 08-13-3
PAGE 3
I think you are dreaming if you think this TSB is going to improve mileage. It looks a lot like a re-gen preconditions calibration change.
MFM
N9MB
Indiana
Posted: 08/20/08 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't had the new flash long enough to speculate on the mileage but it certainly cured the cruise control resume issues which I was pleased to see.
F350 PSD CC DRW Tow Boss
Heartland Bighorn 3600RE
Airsafe Revolution
kmh3212
Georgia
Posted: 08/25/08 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 2008 F450 with 4.3 rear end. It is a Job 1 truck built in May of 2007 with 30,000 miles. It is in for the first re flash of the PCM powertrain control module. This is a computer controlled engine as is all modern diesel engines. The EPA is mandating emission requirements that choke the life out the all new diesel engines. Ford is spending big bucks to ensure that we can get the maximum performance and economy from the new 6.4 liter diesel staying within government requirements. Ford is listening to the loyal customers by continuing to improve their products well after the sale. I will gladly drop my truck in for a 30 minute PCM update that will improve my trucks performance.
I bought another Ford because I wanted a fantastic truck with looks and guts. The F450 product is in a league by itself.
BTW I am getting 12.9 mpg hand calculated with the old math empty some city mostly highway. I can't wait for service pack 1!
Camping with Cash
East Kingston, NH, USA
Posted: 08/26/08 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Well Said!
If you are going to knock Capt. Skup's F-450 then knock it with a comparable truck/5er, not a 2001 dump truck.
Jim & Rhonda Titus
Cash, The Brindled Boxer
Bruno, The Flashy Fawn Boxer
2004 Cedar Creek Silverback 28LRLFS 5er
2006 Ford F-350 Lariat FX4 CC 6.0 PSD
Reese 16K Kwik Slide
Tuxbury Pond RV Resort Site #96
marek
Ellicott city MD
Posted: 08/26/08 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
how long are the DPFs good for. Will they make it till 200k ?
ib516
Up here!
Posted: 08/26/08 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt they'll go 200K without service. I believe the idea is they be removed and cleaned with what looks like a Monster Garage type Vacuum. My thinking is that they may be rusty and fall apart when they attempt to remove them, and they'll need to be replaced.
That goes for all the brands equipped with a DPF, not just Ford.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
surveyorjp
Missouri
Posted: 08/26/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Well Said!
Sad thing is, that old "dump truck" gets better fuel mileage than the newer diesel engines. Even your beloved Ford with the 6.4l PSD. That was my point, the fact that today's diesels just do not get great mileage of those just a few years ago. And the 6.4L PSD is the worst one of the bunch in regards to fuel economy. I don't blame Ford so much as I blame the the new emissions regulations forcing them to choke the engines with this DPF nonsense. Ford will likely have an answer for that problem with the introduction of the new Scorpion diesel. Maybe that will return them to a status they once held when the old 7.3L PSD was an engine that challenged the Cummins for diesel dominance. And I am not talking about truck sales, I am talking about the power, efficiency, and reliability of the engines.
* This post was edited 08/26/08 05:49pm by surveyorjp *
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
Page of 5
