RV.Net Open Roads Forum: RV Licence Endorsement in British Columbia
Open Roads Forum  >  RVing in Canada and Alaska  >  Canada
 > RV Licence Endorsement in British Columbia
revrnd
Apsley, Ontario
Posted: 08/11/08 10:54am Link  |  Quote  |  Print  |  Notify Moderator
My brother was saying that BC requires a person towing a RV to have a endorsement on their licence. How does this work if you're from out of the province?
1981 Elan 250
2007 Ski-doo MXZ 600SDI
1986 Monte Carlo SS
2004 Chevrolet K2500HD
2006 Jayco 806 P/U
wilber1
Abbotsford B.C. Canada
Posted: 08/11/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
If you tow over 4600 kilos you need an endorsement but that only applies to BC licensed drivers. Doesn't apply to out of province drivers but doesn't Ontario have the same regulation?
"Never trust a man who has not a single redeeming vice" WSC
balvert
Windsor, Ontario
Posted: 08/11/08 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Ontario requires a Class A drivers license if the trailer (axle weight) exceeds 4600 kilos or 10,141 pounds. See Ontario License Info for RVrs. Ontario license requirments apply to all Ontario drivers no matter where they drive. A BC driver would need to adhere to BC requirments while in Ontario.
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
Gruffy
monominto mb ca
Posted: 08/11/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
Manitoba has a restriction over 4600 kilos as well. But the same agency sells the insurance and the drivers licence there....
revrnd
Apsley, Ontario
Posted: 08/11/08 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
This is what my combination would fall into:
"Class "G" if the truck is registered for and the combination weighs 11,000 kgs (24,250 lbs) or less."
So I guess I'd be OK.
JMTTS
52.1122 N, 106.5625 W
Posted: 08/11/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Check out the following SITE.. Check out Class A with an R restriction (For people pulling Trailers and 5th wheels with GVWR ratings of over 4600KG).
J & M
2005 Cardinal 33TS LX with TrailAir
2004 Chevrolet Silverado 3500 4x4 DRW D/A (LLY) Crew Cab
PavementPilot
Vernon, BC
Posted: 08/11/08 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
well at least I dont have to worry about the RV restriction in BC, as I hold a Class 1 in BC.
DW, 2 girls, and me
07 Freestar
76 Parklane Tent Trailer
08 Minn Kota 30 lb Troller
56 Featherlite 10' Cartopper
Nights camped in 2007: 14
Nights camped in 2008: 10
17 years Professional Driving accident free all over North America
Hamops
Oshawa, ON, CA
Posted: 08/12/08 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If your Ontario "G" license covers the requirement when pulling a trailer in Ontario then it meets the BC requirements.
An Ontario "G" licence is good for a trailer weighing less than 4600KG. The 4600KG is the axle weight of the trailer when it's coupled to the tow vehicle. GVWR of the trailer has nothing to with the type of drivers licence required. To ensure that you are legal, take your tow vehicle and trailer to a CAT scale and weigh it. If the trailer axles weigh less than 4600KG then a Ontario Class "G" Drivers License meets the requirement.
Helen & George VE3INB and Max (Bichon Frise)
06 Silverado LT 2500HD D/A
2006 Crossroads Cruiser CF30SK
Prodigy Brake Controller
16K Reese Slider with
a Bedsaver
Betsy II
BC
Posted: 08/12/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hamops, can you clarify please.
If the towed vehicle (5th wheel) was disconnected on the scale and weighed, is it not this weight that is referred to in the regulations?
The reason I ask is because it does not say the axle weight of the towed vehicle.
thanks,
Roy
Hamops
Oshawa, ON, CA
Posted: 08/14/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
thanks,
Roy
The answer is No.
The Ministry of Transportion in Ontario only looks at the axle weight of the towed vehicle impressed on the road surface with the towed vehicle connected to the tow vehicle.
In my case, I weighed my truck first with the following results. The steer axle = 1790Kg (3945#) , the drive axle = 1430Kg (3152#), Gross weight = 3220Kg (7097#)
Then I weighed the trailer hitched to the truck with the following results. The steer axle = 1730Kg (3813#), Drive axle =2250Kg (4959#) and the trailer axle = 3750Kg (8265#) Gross weight = 7730Kg (17037#)
The kingpin weight is 2250-1430 = 820Kg (1807#)(NB: The kingpin weight becomes part of the truck axle weight and is used to for licensing the truck.)
The gross weight of the trailer is 3750 + 820= 4570Kg (10073#)
The Ontario MOT took these weights and reviewed them for me and made a determination that since the axle weight of the trailer was 3750Kg, and under the 4600Kg rule, a Class G license will meet the requirement.
I've attached the link to the MTO. It has the information that tells you that trailer weight is the weight that the trailer axles press on the road.
Ministry of Transportation - Ontario
