RV.Net Open Roads Forum: Class A Motorhomes: Motorhome not sitting level
 > Motorhome not sitting level
JFG
TN
Posted: 08/11/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
36' HR Neptune DP
With the price of diesel sky high, have been tinkering with mh getting it ready to go when price drops some. I noticed the left rear of mh (drivers side) sits lower to ground than right rear. I measure the distance from the concrete drive to the wheel well opening on both sides and the left side is 1.25 inches lower than the right. I got under it, and measured distance from drive way to bottom of the frame on both sides... they were the same. I measured the height of both rear air bags and they measure the same. Measured front bag height and they are the same height. I took the coach out for a ride and came back and remeasured... same results.
The mh is basically dry... no water or propane.. but those tanks are between the rails anyway.
Should I lower the right side rear bag by about 1 inch or just forget about it.
Any suggestions or ideas. Thanks.
Fred
wolfe10
Posted: 08/11/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
JFG wrote:
36' HR Neptune DP
So, it sounds like some of the body components (wheel well for sure) are not installed on the same level vis-e-vie the frame. Can you look at the lateral frame members coming off the frame that supports the sidewall? How do they look.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
427435
Rochester, Mn
Posted: 08/11/08 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
Measure the distance from the top of the rear axle to a frame member on each side of the axle. That should tell you if there's a suspension issue or a body "fit" issue.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
Badeye
Bonaire GA
Posted: 08/11/08 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with Wolfe10, it sounds like a body to frame fit issue. The measurements you made pretty much say that the frame and suspension are correctly aligned/adjusted. In my opinion you should not lower the airbag height to compensate for it as you will then have the suspension incorrectly adjusted. This can cause all kinds of problems including weight shift problems.
Badeye
"No one can guarantee success, only effort."
Bob & Fran
2005 Coachmen Sportscoach Elite 40 ft DP
2003 PT Cruiser
Featherlite Car Hauler
FMCA F324606
