RV.Net Open Roads Forum: Tech Issues: Running the inverter while traveling
 > Running the inverter while traveling
Gdetrailer
PA
Posted: 08/11/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Sure do, that is how we power our 110V home fridge that we installed in out TT. TV can supply 30A @12V to keep the TT batteries charged while driving. This is plenty since the fridge only uses 90W when running which is 9 to 10A @12V for 20 minutes per hr.
See my RV HINTS and TIPS for detailsCLICKY LINK
Roadpilot
Lakes Region of New Hampshire
Posted: 08/11/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
24/7/365
2007 Newmar Essex 45'
2006 Honda CR-V and 2005 Chevy Silverado 1500
2004 HD Electra Glide Ultra Classic
2006 HD Heritage Softail Classic
Overbilt Lift
jeanspach
New Mexico
Posted: 08/11/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Well OK then. Even with a TT the consensus seems to be 24/7/365.
Joel & Leesa
2001 F-150 SuperCrew Lariat Offroad 4x4 5.4L 4.10 LSD Tow Package
2005 Trail-Lite 8308S 5,162# dry
2 Honda EU2000i, 4 GC2 batteries
rayamash
michigan
Posted: 08/11/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
just make sure that there is enough air circulation for cooling where ever you decied to mount the inverter. And use large enough cables for the dc supply side for the greater amount of amps needs.
Wherever I happen to park
Posted: 08/12/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
All the time, I almost never turn it off. (it automatically switches on or off depending on shore power.. For example this morning I have a 2,000 watt space heater (Yes, it really is 2,000 watts) a Microwave and a toaster, all plugged into a 30 amp park outlet... CLICK and .. The heater turned off, Microwave and toaster did not miss a beat though as the Xantrex Prosine took over
