RV.Net Open Roads Forum: rubber roof losing white color and showing alot of black
 > rubber roof losing white color and showing alot of black
blockmason
Weaverville
Posted: 08/12/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
looking for suggestions on my rubber roof on 98 jayco 5th wheel my roof over time and cleaning has lost most of the white covering and now u see alot of the black rubber but no leaks what do I need to do if anything thanks Darryl
mfox20
Fort Worth, TX
Posted: 08/12/08 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Darryl,
Do a search on "To Coat or Not to Coat, That is the Question"
There was some discussion on this issue.
Michael
Harvard
51.37N 114.42W
Posted: 08/12/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Our 99 MH went the same way but we did not worry about it. Do not use anything other then mild soap, stay away from anything derived from petroleum.
downtheroad
Puget Sound
Posted: 08/12/08 10:05am Link  |  Quote  |  Print  |  Notify Moderator
My feeling on this is that it's a roof...as long as it doesn't leak I don't worry too much about what color it is.
I can't see it anyway and neither can most anyone else.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
mt-pocket
Minnesota
Posted: 08/12/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I'm new at this but I would think that black spots would attract heat and that would not be good. As long as the rubber is good then I would look into coating it.
Gary
One Wife, No Money, Retired
2006 2500HD Chevy Silverado Duramax,
2006 Americana 35/36 5th Wheel
Pressure Pro TMS, Huskey Hitch 16K
TXiceman
(Near) Houston,TX
Posted: 08/12/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I agree. Most manufacturers recommned a mild soap scrubbing and that is all.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
trop-a-cal
Palm Coast Fl
Posted: 08/12/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Time to paint it with two coats of Dico rubber roof paint. It's about $65 a gallon and goes on with roller and 3 inch brush. Wash good first and then after it's dry paint on one coat, waite about two hours, and do second coat. Follow directions on container. Works great! If you have any mold use dish detergent and two cups of Clorox in a bucket for the wash. Rinse until all soap is gone. You might want to take your max air vents off as you can paint right over any caulked areas as it seals the cracks in caulk too. Did my 1997 Tropical and it can out great. Only took two gallons to do my 36 ft class A.
Gale Hawkins
Murray, KY
Posted: 08/12/08 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
20 year fix. Liquid Rubber $65 42sq/gal - not a coating - new EPDM
Southwind98
Maryland
Posted: 08/12/08 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
I used Liquid Roof on my 98 Southwind when the same thing as you described appeared on it. One coat on, easy to use, white in color, attaches itself to the surface, and dries to a hard shell. Still looked and performed well when I traded it in two years after I applied it. Really did the job.
Will & Michelle
2008 Fleetwood Bounder 38P
1990 Jeep Wrangler
othertonka
Stockton, CA
Posted: 08/12/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Could be Mold or Mildew. A small test spot with a little bit of Clorox diluted with water, in spray bottle, will tell you in a minute if it is. Just spray it on, let it sit for a while, scrub with a soft brush and wipe with a wet cloth or rinse with water. If it is mold, it will clean right off. Worth a try.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
