jshirk46
Lancaster,PA
I found it on ebay and got it for 35 plus 15 shipping. Is there any converter out there that I don't need a battery with. I was just checking for a ground on the trailer and there isn't one anywhere I can find. So I am assumming that the battery is the main ground for the camper.
stacaz822
Phoenix, Arizona
I just noticed that there is a switch on the front marked, Converter/Battery. I guess this invalidates my last post.
It looks like you're supposed to use the 120v AC ground as the 12V ground, which should be tied to the frame of the camper. Although the battery neg wire may be connected internally to the 120V ground, you can't be sure. I would connect the radio pos and memory wires to one of the 12v circuits (one of the blue wires), and connect the radio neg wire to the ground terminal on the converter.
Stacaz
stacaz822
Phoenix, Arizona
jshirk46 wrote: I found it on ebay and got it for 35 plus 15 shipping. Is there any converter out there that I don't need a battery with. I was just checking for a ground on the trailer and there isn't one anywhere I can find. So I am assumming that the battery is the main ground for the camper.
I got a PD9260 on ebay for about $120 NEW a couple years ago, and it has very well regulated 12v output of up to 60 amps, with or without a battery. It's also an excellent three stage charger if you ever do get a battery, or bank of batteries. I use it to charge a bank of two 6v golf carts batteries. Excellent product. I can also completely disconnect my battery bank and it still works perfectly at 13.6 volts with any load, including radio and DVD player.
Larry202br
Olathe, Ks
jshirk46 wrote: Is there any converter out there that I don't need a battery with.
You don't want a converter, you want a power supply. Something like this: 12 volt Power supply on ebay
It should be filtered and regulated. If you have a CB or HAM radio store near you, they will carry what you want. A dedicated Stereo shop should have them as well.
2006 Open Road 316 RLDS-5
2004 F-250 Diesel, short bed, SRW, Crew cab, 3.73 auto.
jshirk46
Lancaster,PA
Are you saying buy one on these power supplys just to run my stereo. And use my present converter to run everything else. Seems excessive to me. If thats the case I will just buy an electric stereo and run it off the 120 volt system. i did a search and there are a couple converters out there that will work with or without a battery. Going to my local rv dealer today to talk to them see if they can tell me whats wrong. I belong to pop up explorer forum and a lot of these people are putting car stereos in there campers and are running them off the converter. So I need to find out if it really is not having a battery with the converter I have.
jshirk46
Lancaster,PA
Talked with local rv dealer. He said I do need a battery to stabilize the system. He also said the stereo should not be hooked to a circuit from the converter. He said to hook the radio to the battery lugs on the converter where the wires from the battery hook to the converter. The will give me constant voltage at the radio. Now the question is do I want to add a battery or buy an updated converter? Cost seems to be about the same till I buy a battery, wire it in, buy a box to put it in and install it. Converter I already have the wires there for it and don't need the battery. Only gonna use this camper maybe 4 or 5 times a yr anyway for nascar races.
mike4947
N. Syracuse, NY
Talk to the folks at Best Converter They are very knowledgeable and also very helpful.
They'll give you your best options for the radio and electrical system.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
jshirk46
Lancaster,PA
I talked with ask Randy. at best converter. He also told me to get a newer converter mine is told old to have voltage stabilizing to run todays electronics. Trying to find a good price.
stacaz822
Phoenix, Arizona
Here you go.
jshirk46
Lancaster,PA
Thanks for the link. stacaz822. Looks like the deal I was looking for.
