Lug_Nut
Newmarket , Ontario, Canada
I think I would go with 3 good quality deep cycle 12 volt batteries. Especially if you can not find ventilated space and secure mount for a 4th. Best of lick.
'07 Newmar Essex 45' ISM 500 4 slides
TMBLSN
Washington State
Yeah, sorry, I wrote it backwards.
My original point stands, however, you can't use (3) 6V batteries in an RV; you have to have an even number of 6V batteries.
2006 Jayco 275BHS
1998 C2500
Lee
big dave
Soldotna, Alaska, USA
fncampn wrote: Well actually, you could put 2 6-volt batteries in parallel and then parallel that pair to a single 6-volt battery. While the configuration may be possible, it is likely that the single 6-volt battery will be doing most of the work, i.e., providing the most current of the 3 since the 2 in parallel will be providing the other half of the current draw.
Clear as mud? I wouldn't suggest this configuration. You will find that the single battery will drain much faster than the other 2.
I think you mean two 6 volt batteries in parallel with the third in series to make 12 volts. The way you said it would total 6 volts.
Either way, not a good idea
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
fncampn
Gardnerville, NV
big dave wrote: fncampn wrote: Well actually, you could put 2 6-volt batteries in parallel and then parallel that pair to a single 6-volt battery. While the configuration may be possible, it is likely that the single 6-volt battery will be doing most of the work, i.e., providing the most current of the 3 since the 2 in parallel will be providing the other half of the current draw.
Ooops. Yup, I meant it the way you said it.
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
skipnchar
Topeka Kansas USA
Not a good idea EVEN if you straighten out the wiring terminology.
Deen
Vancouver, WA
Lug_Nut wrote: I think I would go with 3 good quality deep cycle 12 volt batteries. Especially if you can not find ventilated space and secure mount for a 4th. Best of lick. Good quality true 12 V deep cycle batteries are VERY expensive. You won't find them at Costco or Sams, you'll need to find a supplier.
The so called "deep cycle" ones you see locally will be a Marine battery which is a combination starting and house battery. They are NOT deep cycle 12 volt batteries.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
smkettner
You need two sixes and a twelve OR three twelves.
If you somehow have three sixers figure out a way to fit a fourth or trade one for a twelve volt. I found with a single box to hold four six volt batteries it only takes the space of three twelve volt in separate boxes.
knightstar
Reno NV
My motorhome has a tray which holds three coach batteries.
Due to a problem, or problems, with the original dealer, the original batteries had to be replaced.
I purchased three Trojan SCS225, 12-volt, deep cycle batteries and have been quite pleased with the service from these batteries.
Steve
javaseuf
Southern Cal
wolfe10 wrote: As Jerry said, 6 VDC batteries need to be used in PAIRS to achieve 12 VDC.
Jerry didn't mention voltage, just amperage.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
