RV.Net Open Roads Forum: Tech Issues: Tripping GFI receptacles
 > Tripping GFI receptacles
spitfirepete
Great Outdoors RV resort
Posted: 08/12/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot plug the coach power cord into any GFI receptacle without tripping it.....I have turned the main breaker and all other breakers off inside the coach to try to diagnose the bad circuit, but the GFI even trips with the main breaker and the others off......
I suspect this problem has existed since the coach was new, but you so seldom see GFI's that I only recently discovered the problem...Suggestions?
Peter and Linda
2007 Mandalay Presidio ISC
1975 Triumph Spitfire toad
2007 Saturn Vue toad
Bichon and Cocker (spoiled puppies)
wolfe10
Posted: 08/12/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have in inverter? Many tire the neutral and ground which will trip a GFI.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
JesLookin
Appleton,WI
Posted: 08/12/08 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Well when I had my problem I didn't have an inverter, but the neutral & ground where shorted together in the breaker box. Bending the ground lead away from the neutral bus bar fixed the problem. Took a long time to find the problem though.
2005 Sierra 285 BH
2003 Dodge 2500 Diesel, quad cab, short bed
spitfirepete
Posted: 08/12/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I have inverter.....so I should look for crossed wires in breaker box...will do. Any other suggestions?
Alaska Annie
Sheep Mountain, AK,USA
Posted: 08/12/08 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
We have exactly the same problem with our '08 coach. I tried a different GFI circuit- same problem. It works fine on non-GFI circuits. The strange thing is before our last trip, the coach worked well on the same GFI circuit that now trips. Turning off all of the breakers make no difference. With the breakers off, the transfer switch is the only device receiving power, so it may be the problem. Any ideas will be appreciated.
Henry & Ann Tipton
Polishnurse
Schodack, NY
Posted: 08/13/08 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Try unplugging the converter, it is some times plugged into the back of RV panel box. I remember sometime back someone mentioned that a converter can cause the problem. Just another item to check Bill
Jamesrpm
Oregon Coast
Posted: 08/13/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
And check your cord it could have been damaged.
___________________________________________
I plan on living forever , so far , so good
Belgique
Cedar Island NC (Outer Banks)
Posted: 08/13/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem in an '08. Will try these and future suggested fixes. Thanks to the OP.
The Johnsons (incls a Bouvier, Lab, and Newfie)
Cedar Island, NC (Gateway to the Outbanks)
2008 Winnie Sightseer 35J
Our Mexico trip Blog
bigfootford
Fair Oaks, California
Posted: 08/13/08 08:45am Link  |  Quote  |  Print  |  Notify Moderator
You can start by unplugging everything that runs on 120vac. Fridge, microwave, inverters etc. Those are the easy things.
From there it gets tough. You will need a meter and will have to measure resistance of your grounding to Neutral/hot relationship as you disconnect things.
Guys have found wire problems with their built-in gennys, Hot water heaters (110) types, fridges (3 way types, 110,12vdc, propane)etc.
Keep us informed of your progress.
Jim
94 F-250 ex cab,460, E40D tranny,airbags w/pump,bilstein shocks, 2000 Bigfoot 9.6 2500 camper, Progressive Dynamics 9260, Trimetric monitor and an eu2000i honda genny.
Wife and Molly- Ausie,Queensland healer
SWMO
Southwest Missouri
Posted: 08/13/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
If I understand you correctly and its tripping even when the main in the coach is off, you probably have a problem in the cord or at the cord connections.
A GfI senses a current flow somewhere other then the neutral, if there is any leakage through the equipment ground or some other path it will trip.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
