RV.Net Open Roads Forum: Shut off the water when you leave for the day?
 > Shut off the water when you leave for the day?
Page of 6
Tizi
WA
Posted: 08/12/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent tip. Glad you brought it up. Will do in the future.
2008 Dodge Ram 2500 QC 4x4 - HEMI
2004 Northern Lite Ten-2000 CD
1998 Glastron GS 180 SF w/ Merc 150 HP
larry barnhart
wenatchee. wa usa
Posted: 08/12/08 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
always for us.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
pingpong
Posted: 08/12/08 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
WOW! Never thought about that, but now will...thanks for bringing this up!...will also consider doing this while on vacation from our stick house, to!
Husband, Wife, 2 kids, 3 cats
2007 Newmar KSDP 3910
2007 Jeep Liberty
"Whenever I feel blue, I start breathing again!"
"How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?"
3708
modesto
Posted: 08/12/08 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
The first thing we do when we get in the toad is ask, did you turn the water off? if neither of us can answer than one will get out and check and if we get down the road in the toad and can't remember than we turn around and go back to check, i sean first hand from a neighbor what a waterfall looks like coming out the trailer door when he returned from having diner. These rigs are rockin and rollin down the road and i would rather be there to see a leak than come back to a lake and another thing i have met some great people when i went around to turn off the water. 3708
old guy
Oregon (pronounced Or e gun)
Posted: 08/12/08 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
not a bad Idea to do it at home when you leave to go camping. Fiend of mine had the toilet hose break on his home in Yuma and the insurance company just about rebuild the whole house. Now he turn water off in every house when he leave for some time.
bo caballero
sacramento
Posted: 08/12/08 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Never did before, but will from now on.
Lonnie
Breese, Il 62230
Posted: 08/12/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
This happen in Texas this past winter. One night it got down below freezing and the water lines froze. Single woman in TT behind us got up in the morning and tried to brush her teeth. Well the line was frozen so she got out bottled water to use. Then she left to go to her job at the hospital. Later in the day it warmed up and the line opened up. She had forgot to turn off the water in the sink and had her gray tank closed. It didn't take long to fill the gray tank and the water was running out the door. I don't always remember to turn it off but do try when we are away.
Lonnie & Mary
2003 Kountry Star 3301
7 RV.NET Rally's
HTALLEN
Fremont,CA
Posted: 08/12/08 11:22pm Link  |  Quote  |  Print  |  Notify Moderator
Always when gone for the day.
1997 Southwind 32 VS,Banks,SafeTPlus,Bilsteins,Henderson Trac Bar
3 maniac poodles..Mozart,Ziggymonster,Nickolas
Honda Civic
Hookum
Tucson, Ariz.
Posted: 08/12/08 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
I've always had a fear of water lines breaking inside the coach. Thousands of miles of shaking can weaken any one of many fitting.
My personal answer is to always use my on board water pump ONLY. I fill up my tanks and then pump my water. It's easy to always turn the pump off when I'm gone and easy enough to hear the pump running when I'm in.
It also eliminates water pressure spikes or excess pressure period.
In regards to the water bowl almost overflowing comment, mine has two small overflow holes just below the rim, doesn't everyones?
Norbert
alpenliter
Olympia WA
Posted: 08/12/08 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
We came back from lunch to find a waterfall down the steps from the bathroom and out the door. Toilet pedal stuck in the down position. Could have been worse, we had just pulled in and hadn't used the toilet yet, so the black water tank was relatively clean. When we leave the stick house for any amount of time we shut the water off. Just installed two battery operated water sensor alarms under the kitchen sink and in the basement of the 5er under the bathroom. If it happens at night, we'll know it!
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
Page of 6
