Fiver-Get-You-Ten
Chattanooga, TN
One thirty pound tank usually last us through three or four months of full time camping. That is with gas heat, water heater, stove and oven.
Are you sure about 3 or 4 MONTHS running heat, water heater, stove and oven fulltime on 30lb bottle? That's some fantastic "mileage"! Wish my TV would do that good.
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO RIDE-RITES PRODIGY REESE 16K KWIK-SLIDE*** 2008 MONTANA 3400RL
MFinCA
San Francisco Bay Area, CA
jay2003 wrote: I open both LPG tanks BUT I check the indicatator on the autoswitch every couple of days (especially if I've been running the heater). If the indicator turns red then I know the tank on the side the switch is pointing is empty and needs to be filled.
That is the way I do it as well. Here is a link to information about changeovers:
LP Changeover
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
Charlie Q
Brusly, Louisiana
I leave one valved in and the other closed.I can usually guess at how much is in the tank I'm running off of and when it starts getting close to empty, I'll open the other tank as a back up or just fill the one I've been running off of.
With that being said, if I run out while camping and go to the spare bottle, when I refill the empty one, I'll put it in the rear position so that it remains full until needed. I always have a full back up this way.
'03 Chevy CC/SB,D/A,4X4, Airlift Bags, Bilsteins, Reese slider, Hypertech programmer.
'06 Mobile Scout 31 BWFS
Yamaha 3000ISEB
ragenfun
Rancho Cucamonga
Fezziwig wrote: What kind of mileage are you getting? What is your fuel cost per mile?
I haven't calculated that yet. I've had the trailer since March and have gone on weekend trips only (around 4 times).
2008 Chevy Suburban LT 2500
2007 Ragen SS2400
ragenfun
Rancho Cucamonga
Thanks everyone for the reply.
copter
Viagra helps a
Check Costco....
06 GRAYSTONE LBZ | MBRP 4" TURBO BACK | NOR*CALTRUCK 4-6 LIFT | AMP STEPS | 4300k HID'S | KMC DIESELS
06 COACHMEN ADRENALINE 314FS TOY HAULER | CLEAR LEDS | A&E POWER AWNING | ON BOARD AIR
05 HONDA 450R & HONDA 400EX
__________________________________
jay2003
San Joaquin Valley, California
copter wrote: Check Costco....
I got one of those for home use on a 20# tank just for fun. I actually ran out once because at the beginning of my cooking it was green and went straight to red about 30 minutes later when I noticed the flame going down. I think I'll try one with a needle next time.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
NanciL
Bakersville, NC, USA
Ok I'll qualify a bit if that will make you happier:
We head to Florida starting in Jan and come back home in April.
We don't keep the heat turned on during the day, (just as needed).
We do keep it turned on through the night for most of Jan and Feb.
We don't keep the water heater turned on all the time. I just turn it on as needed., (with gas it is a total waste to leave it on round the clock).
If it will make you feel any better, on a four month trip to Alaska I used two tanks.
Jack L
Jack & Nanci
ShapeShifter
Buffalo, NY
jay2003 wrote: copter wrote: Check Costco....
Yep, that's the way they work, even the ones with needles.
This is a pressure gauge, and the pressure in the tank will remain relatively constant until it is empty, and then it will drop like a rock. A propane tank is filled with liquid propane under high pressure, with propane vapor above the liquid. As you use propane, you draw off the vapor, and some of the liquid boils off to replace the vapor. As long as there is some liquid in the tank, the pressure will be the same (it does vary a little bit based on temperature, but does not vary according to the amount of liquid.) The pressure will only start to fall when the liquid is all gone and no longer replacing the vapor being used. But at that point the tank is already empty, and the remaining vapor won't last long.
So pressure gauges only tell you whether the tank is empty or not empty, and that's pretty easy to tell otherwise (because things don't work when it's empty.) It won't tell you how full the tank may be, only that it has something in it.
Reliable ways to tell propane level are by using a gauge with a float mechanism (must be built into the tank or valve) or by meauring the weight of the tank. There are also indicators that can be stuck to the side of the tank that change color with temperature - these can work, but are sometimes cumbersome (the one I had required that you pour very hot water over it to read the level, and even then the level was hard to discern.)
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
WKAYL
Loveland, Colorado
I have heard that if you have one of those infrared thermometers to point at the tank you can tell the level. This only works on a tank that is being used at the time as the temp differential occurs as the liquid turns to gas.
There is no place to boondock in Colorado. Repeat after me, there is no place to boondock in Colorado.
2006 Dura Max LBZ now in the driveway
Reese 16K slider-rocker
26ft Thor 5th wheel
2 Polaris Sportsman 500s
64'6" nose to tail when "Double Towing"
