RV.Net Open Roads Forum: Rockwood 2601 Shower Door or curved Shower Rod?
 > Rockwood 2601 Shower Door or curved Shower Rod?
phurley
Sonoma, CA USA
Posted: 08/12/08 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
I want to install a shower door or bent shower rod to give me more space in my shower. I noticed that the shower has some plugs that I can remove, so I assume there are shower doors that fit. Am I right?
If not, I was thinking of a bent shower rod like in hotels. Anyone seen anything for a TT?
2007 Rockwood 2601
2003 Niagara
Ford F250
4BeachCampers
SoCal
Posted: 08/12/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Check out this thread... I believe this is what you're looking for.
Curved Curtain Rod thread
Link to curved shower rod at Lakeside
1999 Starcraft 21CK
View our Profile for more pics...
Horseplay
NC
Posted: 08/12/08 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
I would go with the shower rod. Easy to replace and less to clean. More room, less weight.
phurley
Sonoma, CA USA
Posted: 08/13/08 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Ordered!! Thanks!!
shadows4
Kansas City, Mo
Posted: 08/18/08 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Literally just finished installing a curved shower rod from Lakeside. Install was straight forward and easy, only took about 20 min. Only negative was lack of communication from Lakeside. Checked earlier today and website still said order was in their warehouse ready to be shipped! Took about 8-9 days to get it.
2000 4X4 Excursion Limited 6.8V10, 4.30, 122,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2004 4X4 Expedition 5.4V8, 3.73 210,000 miles
2000 Coachmen 297 RKS
Reese Dual Cam Sway Control
Prodigy Brake Control
mobeewan
Hampton, Va
Posted: 08/19/08 03:09am Link  |  Quote  |  Print  |  Notify Moderator
I think the plugs you mentioned are for holding the tub surround to the wall. Most likely they are like big plastic thumbtacks with barbs on the shanks (I forget what the actual name for them are) that are pushed through holes drilled through the tub surround and wall paneling. My surround is attached the same way. If you try to remove them you may end up making bigger holes in the wall.
phurley
Sonoma, CA USA
Posted: 09/01/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I bought the curved shower rod at Lakeside and love it. Thanks!!!
