RV.Net Open Roads Forum: Tip-out issue on my 95' Franklin Park model
 > Tip-out issue on my 95' Franklin Park model
karbar
Sister Bay, WI
Posted: 08/13/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Just bought this unit in the spring. Just noticed the other day when washing walls trying to eliminate previous owner's wife over use of Stickup and Plug-in air freshners. She had 20 of them in a 40' unit with two tip outs. Found while cleaning around where the top and one end of the tip out and half the top (its like a lip) that is suppose to be tight against the interior wall was not extended out all the way. At its worst its sticking 2 to 3" into the trailer yet. The tip out is completely level all the way around. Currently the tip out is being support by concrete blocks on each corner. Do you think if I remove the support blocks and get help pushing from the inside this will solve the problem or is something broken? I understand the tip outs are hinged so I don't know why it just would not of just tip out all the way. This unit was moved from another site in the same park a few years ago. So maybe this was the result of do-it-your-selfers. Any thoughts will be appreciated.
RedRamMan
Northeast Kansas
Posted: 08/13/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
First take out the blocks. Maybe your trailer has settled and the blocks are pushing up.
2004 Red Ram SLT QC 3500 Auto CTD HO SB
2001 Cedar Creek 25RLMS 5er
pulsar
Lewisville, NC
Posted: 08/13/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
sum1
So-Cal
Posted: 08/14/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, remove the blocks and gravity will prevail. Then resupport the tip-out. I use screw jacks so I can periodically adjust them. Don't lift them, just barely support them.
MELM
GA
Posted: 08/17/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
The OP inadvertently started a new topic with this reply:
karbar wrote:
RedRamMan, thanks for the reply. I actually did remove the blocks from this corner before I knew there was a problem with the tip-out not being extended (tiped out) completely. I did this with both sets of blocks that are under each corner of the tip out to get them vertical beause the frost had heaved them out of plumb. So I would of thought it would of tipped out all the way just by gravity at that time. But maybe it needs to be pushed out from the inside. I'm just being cautious and don't want to create a bigger problem.
The other thread is closed.
Mel
karbar
Sister Bay, WI
Posted: 08/18/08 07:43am Link  |  Quote  |  Print  |  Notify Moderator
karbar
Sister Bay, WI
Posted: 08/18/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Thanks RedRamMan and Sum1 I'll give it a try when I get up there next weekend.
