RV.Net Open Roads Forum: General RVing Issues: Slide-Out Jacks/Stands - Yea or Nay?
 > Slide-Out Jacks/Stands - Yea or Nay?
jorn
Twin Cities
Posted: 08/13/08 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I did a search and didn't come up with anything, so here goes...
Supports under the slide-out. Love 'em or hate 'em?
2001 Coachmen Leprechaun 314SS (Acquired in July 2008)
dicknellen
Northern Nevada, USA
Posted: 08/13/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
We were told not to use them on our Winnebago by the owner of the dealership.
LetsRV
Portland, OR.
Posted: 08/13/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Generally not considered a good idea. If for some reason the rig settles or shifts you are putting a great stress on the slide out and may cause problems.
The slide outs are made to hold their own weight so no real need to put jacks under them.
Some will say they (the jacks) help to stablize the rig. For the potential problems (and cost thereof) the additional stabilization isn't worth it (in my not so humble opinion)
We are all good at something.....
I just happen to be a good bad example.
Occasionally in error but never in doubt.
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
Posted: 08/13/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
no on the stands, while they seem to make it more stable, if the unit settles and the stand don't you will be creating force on the side outs. This may depending on the amount of difference in the forces damage them. I live in my TT full time and have the side out without the stands and with no problem.
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004.
My Homepage and Rv pics press here
Polishnurse
Schodack, NY
Posted: 08/13/08 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
No to the stands. If you want stands you should have bought a pop out. Your slide out is flanged to make a seal on three sides. If you put tons of pressure on those flanges which will happen even if you rock the unit you will either pop out the wall, or break the flanges off the slide out giving you more space inside, but not very weather resistant. JMHO Bill
ScottG
Bothell Wa.
Posted: 08/13/08 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
No way - for the reasons others have stated.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
outdoorsman2007
In the Woods - Somewhere!
Posted: 08/13/08 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Your slides are made to handle weight without being supported. Also, as mentioned above, you can damage your slides if your rig moves, even slightly, while you have the slides supported.
They are an all around bad idea.
tvman44
Southwest Louisiana
Posted: 08/13/08 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
No way they could do more damage than good.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
CPC
San Fernando Valley, USA
Posted: 08/13/08 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! I guess the consensus is not to use the stands. When I read the manual that came with our unit it said not to put anything under the slideout. So "no stand" vote for me too.
local temperature
Our Pics.
Hornet28BHDS
Parker, PA
Posted: 08/13/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I think I'll say Nay on this one.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
