RV.Net Open Roads Forum: Truck Campers: questions, 7way splitter? etc....
 > questions, 7way splitter? etc....
liv2ryde
Lansing, MI
Posted: 08/13/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know if it is possible to get a splitter for a 7 way? Both my truck camper and my cargo trailer want to plug up, but I only have one on the truck.
Also when I plug my camper into the truck I get no interior power/lights. I thought I should, I have an inverter on board, could something be wrong? Do I need to install a battery in the camper for them to work? Come to think of it the lights inside my cargo trailer quite working too when pluged in to the trucks 7 way. hummmm..
Thanks for listening to my questions!
54suds
adk mts.
Posted: 08/13/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.torklift.com/p.php?w_page=wiring_harnesses
05 Ram xcab drw 4x4 4.10... 06 Bigfoot 25c10.6e....
jsmmv
California
Posted: 08/13/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
The ignition switch in the truck needs to be on before you will get any power to your trailer plug.
malonetravels2
Posted: 08/13/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 7 way with the extra four way converter on the side. This came in handy when we were wiring our Honda CRV with brake assist and extra lights to tow behind our TC. Not sure who makes them.
2001 F 250 Lariat Super Duty Ext Cab Diesel V8 4x4 Off Road and Camper packages, AutoZone HD off road shocks, Timbrens; 1996 Roamer RV Fiberglass Camper; 1998 Honda CRV dingy
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 08/13/08 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have one of these on my truck. I ran the long end up to the front of my bed and mounted it to the bedwall like the 5vrs do. One of these days I intend to remove the plug that connects to my truck's trailer plug and wire it directly into the back of it for a cleaner appearance.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
Zig
Indiana
Posted: 08/13/08 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
I bought This one on E-bay. It works good.
I had to search long and hard to find this one.
Better to Zig then Zag!
Go To "MY PICTURES"
My other Pictures and add a Comment!
liv2ryde
Lansing, MI
Posted: 08/14/08 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Yep, thats exactly what I am looking for, glad to know it is done, I just need to find one. I will check locally then go online. Thank you so much!
I will have to try the turn my ignition on sugestion for my inside camper and trailer lights. I thought I had but maybe I did not have the key turned far enough. So the outside running lights work even if the ignition is off but the lights inside only work with the ignition on, correct? So then my frig and outlets (inverter)will only run on the 12v if the ignition is on unless I install a battery? Thanks so much!!!
Spott
48197
Posted: 08/14/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Here's another one from Ebay, but the long end is only 5'.
Clickable link
Me - Kim - Spot
2005 204 ssi on the water - TCM article
Camp, Forrest, Camp!
Boise, ID
Posted: 08/14/08 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Correct. To prevent you from running down the truck battery, the manufacturer designs the system so that power is only supplied when the truck is running. To be certain that everything is working right, you can start the truck and test everything.
If it still won't work, make sure that the appropriate steps have been taken to sctivate the charging line. Some manufacturers require you to add a fuse or connect a wire.
-2000 Chevy K3500 CC DRW. 7.4L, Auto, 1985 Lance 900, 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust, Hypertech.
liv2ryde
Lansing, MI
Posted: 08/14/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I was able to have a local hitch business build me an adapter for $30. No luck on the 12v to the camper interior, just not working. I plug in the 7way from the camper to the truck and all I get are exterior running lights. I am headed out for the weekend, but I will post up what kind of converter is on board etc. next week. Thanks
