RV.Net Open Roads Forum: Fifth-Wheels: Theft security of fifth wheel hitch
 > Theft security of fifth wheel hitch
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 08/13/08 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I ran a vinyl coated thick aircraft cable thru the waytubes on my PullRite SuperGlide and a couple of hefty padlocks to the in bed tie down rings. It'll slow them down! With the pins I replaced the retainer clips with stainless steel cotterpins, bent at the end, you'd need strong pliers to remove them...again to slow the ruffians down!
RECVEH2005
Camano Island, WA, USA
Posted: 08/13/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
On my HiJacker manual sliding hitch, I lock the hitch head to the base. The total assembly weighs about 240 pounds. The hitch is now over 7 years old and has some rust spots. If anyone can lift that brute out of the truck, they would have to want it really badly.
Mike
Mike & Donna Scheer
Camano Island, WA
2006 GMC 2500HD D/A(LBZ), 4wd, Ext Cab, SB
2004 Okanagan 29-5Y, 1 slide
terrillr
Fort Worth, TX
Posted: 08/13/08 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
We got the pull pin locks from etrailer.com, they work great.
Pull Pin Lock Plates
sirdrakejr
Las Vegas, Nevada
Posted: 08/13/08 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
I drilled out the pins and put locks thru them NOT to keep the hitch but so some fool doesn't take the pins when I travel. When in storage, I lock the hitch on the trailer pin and so far no one has sawed the pin off to take the hitch.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
PackerBacker
Montreal, Quebec,Canada
Posted: 08/14/08 03:56am Link  |  Quote  |  Print  |  Notify Moderator
Cox89XJ wrote:
Most crooks are to lazy to steal a fifth wheel hitch. I've never thought about locking it. I do lock the mechanism shut while pulling to keep some kid from pulling the level to unlock the hitch.
I thought so too until my wife's co-worker had their hitch stolen out of their truck in a local restaurant parking lot. I now have small padlocks on 3 of the 4 leg pins and a pin-lock for the 4th. I also have a padlock on the main swivel head pin.
The other type of theft that I've heard of is kids (I'm saying kids; could be anyone) pulling one of the leg pins out.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
jimw606
Morehead, Ky.
Posted: 08/14/08 04:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for your replies: I have a Curt Q5 Hitch. It comes off in 2 sections. I believe the Pull Pin Plates that Terrelr mentioned will work on the bottom pins. Not sure what to do on the top pins. The Q5 comes off in two sections. I have asked Curt, but no answer yet. I am going to order the pull plates. Thanks guys.
tncruiser
collierville,tn
Posted: 08/14/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Good thing they don't have any copper in them or the thiefs around here would be carjacking you just for the copper. They are taking copper from everywhere. Plumbing, wiring, a/c units. If they ever figure out how much a hitch weighs they will take them to sell for scrap. They have been stealing the carts we use for deliveries at work. They cost us about $350 apiece. I keep my jaws padlocked(DW says it is quieter) when towing. Never though about someone pulling the pins from the rails. I guess I have a new project.
Keith & Patty / TN.
2004 27rl Crossroads Cruiser
2006 Ford F-250 Lariat
The older I get. The better I used to be!
csperan69
florida
Posted: 08/15/08 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Frank
I also drilled out the pins and used 4 same key locks in place of cotter pins.Not theft-proof but will take a bolt cutter to cut all 4 'small' locks
Also use a lock on FW hitch head and transfer it to hitch pull rod when towing so cannot be released by anyone while unit is parked while eating,shopping,etc.
marvmarcy
Polson, MT, USA
Posted: 08/15/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
I don't worry about theft, but my hitch weighs over 800lbs. It was installed using a fork lift and is bolted and welded in place. I've been amazed by unusual thefts, so I understand your concern. You just never know. I do lock my hitch when towing to keep "pranksters" from releasing it and causing the fiver to drop.
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
4-to-camp
Concord, NC
Posted: 08/15/08 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I actually just use a reciever pin with the lock on one end that I bought at Walmart. I have a reese hitch and it is a tight fit but I figure I only needed to lock one down so for 12 bucks I eliminated the worry of someone stealing it.
4-to-camp
Jim,Kim,Sydney,Gordon
2004 Dodge Ram 2500 CTD 4X2 4:10 QC LWB
2008 Wildcat 32QBBS Reese 16K
