RV.Net Open Roads Forum: Tow Vehicles: Allison Tranny Heat/Noise
Search only in Tow Vehicles
 > Allison Tranny Heat/Noise
retired frog
albany,ny
Posted: 08/13/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Have an 07 2500 D/A Silverado HD Classic pulling a 10K 5er. Today in California the temp got up to 103 degrees on rte 20 over hills to Williams. The tranny temp nudged past 200 and the tranny was whining and moaning intermittently uphill which I never heard in 20K miles. Most of my towing has been in relatively cool temps.
Checked the dip stick per instructions cold and hot. Cold was in the zone but hot was just at the lower limit, which according to the manual is 1 qt. down. I doubt this would cause the problem & intend to add oil.
Anyone have experience with this? I'm in Cal. heading for NY with probably some serious climbs so should I have a dealer check it out?
killerbee
PHOENIX USA, Never hot
Posted: 08/13/08 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking you were not hearing the tranny, but the fan.
Normal stuff.
Duramax Cooling System Evaluation
Intro to TURBODIESEL INDUCTION OVERHEATING
THERMAL FEEDBACK and INDUCTION OVERHEATING
GM Overheating
Engine Oil Cooling
FORUM for Duramax Performance
Tune Your Own GM Vehicle
GSS0816
Chestertown MD
Posted: 08/13/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure that the moaning and whining noise wasn't the clutch fan and the turbo working harder? 200 isn't that warm for the allison, did the fluid still look red?
coolbreeze01
Redding, Ca
Posted: 08/13/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Can't help with the trans, but could you send some of that cool air up here?
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
skipnchar
Topeka Kansas USA
Posted: 08/13/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
200 sounds pretty normal for towing in the heat. I'm ALSO betting it was the fan or the clutches driving it. 10,000 lb. is also a pretty light load so shouldn't be putting much stress on the transmission.
jshul
Belmont, CA
Posted: 08/14/08 12:33am Link  |  Quote  |  Print  |  Notify Moderator
As stated by others....200 degrees seems in the "normal" range.
2002 Holiday Rambler Presidential 30'
2005 GMC 2500 Sierra Duramax/Allison
Crew Cab/Short bed/4x4
retento
Rocky Mount N.C.
Posted: 08/14/08 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Mine runs about 200 this time of year just going after the groceries!! 3500, 8.1/Allison.
