RV.Net Open Roads Forum: Tech Issues: Black Tank Repair - Plastic Welder
 > Black Tank Repair - Plastic Welder
Falcon Driver
Orange County
Posted: 08/13/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have a class B Falcon 190 with a slight crack on the top of the black tank near the stem where the release valve is. It seems it has been rubbing on the frame over the years. Can anyone tell me the actual material of the plastic tank and has anyone used a plastic welder to repair? Any suggestions would be great. Thanks
USAFBILL
Alabama
Posted: 08/13/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have a plastic welder but my problems have always been where I couldn't get to the site withour removal so opted for easier repairs. Eternalbond tape will work great on repairs like this.
Polishnurse
Schodack, NY
Posted: 08/13/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you have played with a welder, I think you will find this they best way to go. It's a good repair and will most likly last longer then you. Serious give it a shot. I would just wash the area with a little spirts first to make sure it has a good clean service then a little 200 sand paper. Bill
Tenn Stud
Northeast, TN
Posted: 08/13/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
The tank is made of polyethylene same material as a milk jug. There no way you are going to find any material that will adhear to that material. No paint, no glue. I personally don't think the tape will last long. I spent over half of my life in the plastic business, When my black water tank was split from a blowen tire I repaired it with JB weld, A piece of aluminum and sheet metal screws. I covered the split with JBW about 1 inch each side of the crack screwed the alum to the tank then covered the alum and the screw heads with JB Weld. Never had any problems with it leaking. Kept the rig several more years. I have used plastic welders on about all kinds of plastic. They don't do well on polyethylene and polypropylene. In order to get any kind of adhesion to either of the two materials for must first flame treat the material before doing anything. Hope this helps
Rodger
Tucson, AZ.
Posted: 08/14/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Moved from "CVC".
sljkansas
Miami Co. Kansas
Posted: 08/14/08 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I fixed my old class C black water tank with the 2 part epoxy that come in the plunger type tubes. I use the 5 minute type (Wal-mart has it in the paint area with all the glues). Mix it up and use a flat stick (popcycle or tounge depressor. It is still holding after 5 years. I have also used the JB weld putty to fix larger holes.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter in College
Miami CO. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
BillyW
North ID
Posted: 08/14/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
When I added tank heater pads, the one on the black tank definitely didn't want to stick very well. I ended up using Eternabond around the edges. It appeared to stick quite well. I can't verify it's still stuck since I insulated and covered the tank after that.
'97 F150 4X4
'04 Pioneer 18T6
stevenal
Newport, OR, USA
Posted: 08/14/08 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Repair a RV polyethylene holding tank using A-Seal
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
