RV.Net Open Roads Forum: Travel Trailers: Fresh Water Tank Safety
 > Fresh Water Tank Safety
paedbo
ct
Posted: 08/14/08 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Here's a question for ya, when i went to redo my piping in my trailer, I believe I saw specs for plastic ( pex) piping stating maximum safe levels of chlorine. It was only a few ppm. So I'm wondering how safe it is to run it through the faucets and leave it there?
mockturtle
Northwest
Posted: 08/14/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
The only time it's necessary to keep chlorine bleach in your tank (very small proportion: 1 tsp. per ten gallons) is when traveling in Mexico or adjacent central American countries where water must be purified to be safe.
We always filter our drinking water using a Brita filter pitcher which is then kept in the refrigerator. If the water has chlorine in it, the filter removes the chlorine smell and taste and if it's not chlorinated (but considered safe, as campground drinking water) it removes unpleasant flavors due to minerals, etc.
We only carry a couple of gallons of 'bottled' drinking water for dire emergencies.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
Dixonmatco
Santa Rosa, California
Posted: 08/14/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
There is so much differenct in water types and quality that there are many correct answers. If you have well water, there are many possibilities of minerals, etc.
If you are on a city water system, like we are, there is chlorine in the water and using the bleach or other similar substance is not necessary.
I always keep some water in the tank, but drain and refill it to the level we will be needing (if we drycamp: 100%, unless we have a long drive to get there) (hookups, 1/4 for use on the road)
I always use an inline filter when I fill and I replace it once a year. I also use a Brita pitcher in the fridge.
Been doing this for 15 years with no problems.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
MFinCA
San Francisco Bay Area, CA
Posted: 08/14/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Another option to sanitize is to use Idophor. It is a sanitizing solution that is used in restaurants. It approved for use by most health departments.
Those of us that brew beer at home use it for all our equipment. Any homebrew store in your area will have it available. This stuff is pretty cheap--I have a 1 quart bottle that cost about $10. I use 1/2 oz. for 5 gallons, so a little goes a long way.
I use it to sanitize my freshwater tank. 4 oz. of the stuff into a tank of water. I let it sit for 1/2 hour. According to the Idophor directions, rinsing isn't necessary, but I do it anyway with another fresh tank.
Then it is ready to be filled for use.
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
mecreature
Indianapolis, IN
Posted: 08/14/08 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Cup of bleach in FW tank.. fill, run through everything then empty rinse. Do it a couple times a year.
I take drinking and cooking water and use tank for the rest.
I have ran out of drinking water and have used the tank a bunch and filled at CG and not probs yet..
Hornet28BHDS
Parker, PA
Posted: 08/14/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sanitizing the tank regularly does wanders!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
rolnrolnroln
WA
Posted: 08/14/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
I hope that folks worried about cooties in the FW don't consider the setup of nearly all FW systems. It'll keep them up at nite. No matter how pure the water is that you put into the tank, things will get in. All FW tanks (non-pressurized ones) have a vent somewhere to allow air in when water is taken out. The tank would collapse without one. This vent is not filtered in any way. So, as you pump water out, regular ol' microbe laden air is coming in. Also, the tanks breathe through that vent. When they heat up in the daytime, air goes out. When the tank cools at nite, outside air comes in. Then there are the altitude changes......
There is at least some mold and bacteria in all outside air. That's one reason our bodies have immune systems. We've been drinking FW from the tank on 5 different TTs over 35 years of RVing and haven't died yet. Not even a sickness from the water. We follow the usual "bleach at the beginning of the season" routine in the TT tank and the FW tank in the truck. I suppose if someone had a compromised immune system due to a disease, things might be different. But if your body is "normal," drink and be happy!
Learjet
Louisiana
Posted: 08/14/08 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
we use bottle water for drinking and cooking also, but what are you guy's doing when brushing your teeth?
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
Charlie D.
Gonzales, La.
Posted: 08/14/08 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Granparents lived in the country. They had well water and a tank that captured water from the metal roof. They always drank the water from the roof. Looked in the tank once and could see the algae.
Tried it once and it was the foulest tasting stuff I ever tasted. They lived into their 80's.
Santizing once a year is good. I think we worry too much about our water in our tanks.
They also butchered their own cows and hogs. Made blood boudin if you know what I'm talking about. Also drank warm milk from the cow and never pasturized it. Used the hog lard for cooking. The old folk's sure were tough.
* This post was edited 08/14/08 04:16pm by Charlie D. *
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
Sluggo54
Madison, SD
Posted: 08/16/08 02:53am Link  |  Quote  |  Print  |  Notify Moderator
PointyWombat wrote:
Sluggo54,
What would you consider an extended period of time? A couple weeks gap between trips, or months?
Thanks,
PointyWombat
Great question, tough answer! It will vary depending on your climate, time of year, yada. In a freezing winter, it could be all winter. In a hot summer climate, for me a couple of weeks is enough to bring out the Clorox.
As for ingestibles, nothing I am willing to ingest is going to keep bacteria at bay.
Once you get it down to a routine, it really doesn't take a lot of your time to do it, as long as you have something else to do while the mixture sits in your tank and lines. You can use more bleach and less time, or less bleach and more time. Either way, it takes contact time to do the job. The recommended bleach ratio is effective, but not more concentrated than needed. A bit more won't hurt anything, but will take longer/more rinse cycles to get the concentration down to a level where you can stand it...
Sluggo
DH = Bruce, DW = PK, DD = Maggie (Lab, Pointer, Viszla)RIP 4/13/2007
Apprentice Princess = Kaia Grace (Blue Heeler - Wire Haired Terriorist) Thanks, New Nodaway Humane Society, Maryville, MO!
TV = 2005 Chev CC LWB Max & Allie
5'er = 2005 Excel R30CKW
