RV.Net Open Roads Forum: Tech Issues: Tip-out
 > Tip-out
karbar
Sister Bay, WI
Posted: 08/14/08 07:23am Link  |  Print  |  Notify Moderator
RedRamMan, thanks for the reply. I actually did remove the blocks from this corner before I knew there was a problem with the tip-out not being extended (tiped out) completely. I did this with both sets of blocks that are under each corner of the tip out to get them vertical beause the frost had heaved them out of plumb. So I would of thought it would of tipped out all the way just by gravity at that time. But maybe it needs to be pushed out from the inside. I'm just being cautious and don't want to create a bigger problem.
outdoorsman2007
In the Woods - Somewhere!
Posted: 08/14/08 08:31am Link  |  Print  |  Notify Moderator
You may have created a bigger problem by putting support under the slide out. Not a wise idea.
samsontdog
Sac. Ca summer, Yuma Az winter
Posted: 08/14/08 09:31am Link  |  Print  |  Notify Moderator
I believe he has a tip out ,not a slide out. Big difference
samsontdog
outdoorsman2007
Posted: 08/14/08 10:31am Link  |  Print  |  Notify Moderator
My bad... i stand corrected.
 > Tip-out
