hugsfamily
MD
Our 2008 Passport 240qs has a greater width between the tires than most trailers do. To measure from front to back tire at the smallest distance it's 16". I know that there are other Keystone products out there with this issue. My question is....I would like to use scissor chocks between the wheels, but I haven't found any that extend wide enough. Anyone know of any good ones?
Hugsfamily
(DH-Phil, DW-Mindy, DD-Amanda, DS-Spencer and our Shelties-Polly and Spirit)
2008 Keystone Passport 240QS
2002 Chevy Tahoe 1500 LT, 5.3 V8
Equalizer Sway Control
Mindy's blog
Our Pictures!
pammi
Westland, MI
You can make your own. Do a search. That's what I did. I don't have a Keystone though.
2004 Rockwood Roo 23B (new to us)
2006 Nissan Xterra
When we camp, it's DH & me mostly. Occasionally step-daughter (16) comes, though not necessarily her choice
strollin
San Martin, CA
Wow, 16" is pretty wide spacing for a scissor type chock. Something like this might work for you, BAL locking chock. They're not the scissor type though. These claim they expand to 22 1/2 inches but install at the widest tire clearance so they might not extend far enough for your TT.
You might be able to make some like a previous poster mentioned, however you would probably need 2 threaded rods per chock due to the wide spacing. Here is a link to some plans for the home made kind: Home made chocks
edited 08/14/08 07:44am by strollin *
Me, her, 2 boys & 2 girls
'05 Chevy 2500HD LT 4x4, D/A
Reese Dual Cam HP
'04 Wilderness Advantage 290FLS
Twin Honda 2000s
"I'd rather wear out than rust out!"
"Two hands at work accomplish more than thousands clasped in prayer"
See our pics here
downtheroad
Puget Sound
16" is really a lot and in my experience somewhat unusual. I would bet that you are going to have to go with wedge on the ground chocks for your set up. Possibly you could make your own, but that too could be difficult given the spacing.
GOSH, I just realized that I have been absolutely no help at all!!...
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Vader1
Manch Vegas NH
let me take a stab at this then.
I have a 08 Zinger 30BH I just got these large wheel chock set this is what I have & they fit mine fine.
good luck
edited 08/14/08 01:42pm by Vader1 *
Vader1 aka Jay
Wif aka Kim
Bear aka #1 pug
Chewy aka #2 pug
05 Ram 1500 Quad Cab 4x4 - Yeah it's got a HEMI
08 Crossroads Zinger 30BH
JJBIRISH
Butler, PA, USA
extended tire spacing is good if they did it for stability reasons...
if they did it to lighten the chassis even more by spreading the weight over a larger area, it may not be so good...
anybody know the official reason for it...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
dodge guy
Chicago, western subs.
They say it is to add stability to the TT. the idea is the farther apart the spacing the more stable the towing will be.
I have seen homemade chocks made out of 4X4`s with a threaded rod through both. the ends are cut at an angle to fit tight against the wheel.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
hugsfamily
MD
It's to add stability...I'll tell you we get a much nicer ride out of our Passport than we did our Antiqua. Not sure it's the tire spacing, but not sure it isn't.
Thanks Vader..we had those with the antigua..wont work on the new trailer...the space between the tires is much to far apart. Still looking for a good scissor chock option..I just prefer them....esp. when you have to use your levelers...easier to get a scissor chock in.
twinsmom04
BC Canada
I've got the same problem and havent' found a commercial option yet. I've been working on the homemade ones but having problems with that because of the bar that goes up between the tires to the bottom of the TT.
I've settled so far with the little plastic chocks and just making sure we drive up onto them and slip the second one behind it and settling down into it. Since we started doing that little drive up onto the front one, we have had minimal if any motion. And no-one has stolen our chocks again
TV - 2007 Silverado Crew cab shortbox with 5.3l engine
TT - 2007 28BHS Passport
campers include me and my 4 year old twin boys and occasionally DH
DocP
Brunswick, Ohio
hugsfamily wrote: It's to add stability...I'll tell you we get a much nicer ride out of our Passport than we did our Antiqua. Not sure it's the tire spacing, but not sure it isn't.
Same here with our Keystone FreedomLite 281RL (the same as the Passport 285RL). We just completed a 5,000 mile trip throughout the west and southwest, and the stability of the spread axles was great (although I'm sure a good hitch and sway control helped as well)! When we first got the TT I had the same question wheel chocks and spread axle designs. My search found nothing commercially available, and BAL indicated that there are no plans in the works to make them because there isn't enough of a market for them.
2008 Keystone Freedom Lite 281RL
1998 Breckenridge Park Model
2004 Chevy Avalanche, 5.3L, 3.73:1, 4X4,
Auxiliary transmission oil cooler,
Z71 off-road towing package
Reese Trunnion WD, Dual Cam, Prodigy
Yamaha EF2400IS generator
