RV.Net Open Roads Forum: So what is my Tow Rating/Capacity? 08 Dodge 2500 Cummins
Search only in Tow Vehicles
 > So what is my Tow Rating/Capacity? 08 Dodge 2500 Cummins
krazymatt
NM
Posted: 08/14/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Well after hearing 3 different numbers from three different salesmen and reading the owners manual which is kinda misleading, what is the tow capacity of my new TV? It's a 08 Dodge 2500 Cummins 6-Spd, Auto, 3:73 gears, with the exaust brake. I know the GVWR of my TT is about 9500lbs so I know I'm okay, just curious what the trucks tow rating is. Thanks.
New Mexico
2008 Forest River Puma 26RLSS
2008 Dodge 2500 SLT Big Horn QC Cummins 4x4 6Spd Auto, Exhaust Brake.
Easy-Lift 1000 WD hitch.
2400IS Yamaha Generator
donn0128
Pronounced Ore-gun
Posted: 08/14/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
According to the 2007 brochure the GCWR of your truck is I believe 20,000 pounds. So in reality IF your truck scales at 8000 pounds in ready to camp configuration and IF YOU decide to stay within the manufacturers ratings, then your truck should have no problems pulling 12,000 pounds of TT.
Donn
GBuilders
Boerne TX.
What type of cab do you have? I think the 2500 are around 13-14K for tow rating. Someone on this forum will know what the answer is or check the Dodge website. If your towing 9500 you will have no problems with your new truck.
2007.5 Dodge Megacab DRW 4x4 6.7 w/6 speed auto, 3:73 & prodigy BC
2005 Jayco Eagle 305 BHS
coolbreeze01
Redding, Ca
Posted: 08/14/08 09:10am Link  |  Quote  |  Print  |  Notify Moderator
21,000lb GCWR
12,850lb towing short bed.
12,700lb towing long bed.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
JustLabs
Washington State
Posted: 08/14/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
coolbreeze01 wrote:
21,000lb GCWR
There you go.
Weigh your truck ready to camp, subtract that from the GCWR,and you have your tow rating.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
krazymatt
NM
Thanks. It's a Quad Cab short bed BTW.
MikeRP
Circleville OH
Posted: 08/14/08 10:08am Link  |  Quote  |  Print  |  Notify Moderator
The manual has to be studied. But here's my thoughts. Your 2500 is the same as a 3500 SRW without the extra rear spring.
So look at the the brochure in the tow ratings section for a srw 3500.
The numbers above are for a 3500, I beleive. Payload is the only thing not listed and if I remember right that's around 2800 lbs.
Mike
wa8shc
Parma, Ohio
Posted: 08/14/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
According to the sticker on my 07 2500 QC, the Max Carrying Capacity is 2580#
That's supposed to include Passengers, and Cargo (read hitch& pin weight for 5th)
The 12K(4x4)-13K(4x2) Tow capacity has been the same for abt 4-5 yrs
JMHO
Denny WA8SHC and Rita WB8TIR
Siberian Husky Ta'kya (Princess RIP 10/04 Taz RIP 5/12/08)
2007 Dodge Ram 2500 Quad Cab 5.9L CTD 3.73/LSD,Quadzilla RECON monitor
2008 Rockwood 8243S 5th wheel
Pullrite 14K Superglide & MorRyde pinbox
mking
Indianland,South Carolina
Posted: 08/14/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with wa8shc.Mine is 13,800 with the 4;10 gears.
2006 Dodge Quad-Cab 2500 CTD,4;10 gears,pulling a Forestriver Flaggstaff 831qbss
camping man
Central Fla.
Posted: 08/14/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
My 05 2wd is 13400lb., if I remember correctly.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
